Go Back   TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum > TBSS Drivetrain > 4L70E Transmission Help > 4L80E/4L85E
Old Jan-22-12, 06:41 AM   #1
devus1
devus1's Avatar
Real Name: bubba
Member # 1713
Casino cash: $560680
Rep Power: devus1 has a brilliant futuredevus1 has a brilliant futuredevus1 has a brilliant futuredevus1 has a brilliant futuredevus1 has a brilliant futuredevus1 has a brilliant futuredevus1 has a brilliant futuredevus1 has a brilliant futuredevus1 has a brilliant futuredevus1 has a brilliant futuredevus1 has a brilliant future
Default 4l80 converter
Im little confused guys. Ive seen some say that we can use a stock or aftermarket billet (still in the 4l70 configeration) flex plate and some saying this tranmission will need a crank spacer.....can someone clear this up for me?
AKA "LIFT QUEEN"
Old Jan-22-12, 06:52 AM   #2
truckshop
truckshop's Avatar
Real Name: Shelton
Member # 6438
Casino cash: $109800
Rep Power: truckshop will become famous soon enough
4l80 trans uses a much flatter flexplate and a spacer between it and the crank. Or you can have a hybrid convertor made.
Old Jan-22-12, 07:18 AM   #3
Rat Raceway
Oil Rat, Oil & fuel parts
Rat Raceway's Avatar
Real Name: Ross
Member # 61
Casino cash: $933366
Rep Power: Rat Raceway has a reputation beyond reputeRat Raceway has a reputation beyond reputeRat Raceway has a reputation beyond reputeRat Raceway has a reputation beyond reputeRat Raceway has a reputation beyond reputeRat Raceway has a reputation beyond reputeRat Raceway has a reputation beyond reputeRat Raceway has a reputation beyond reputeRat Raceway has a reputation beyond reputeRat Raceway has a reputation beyond reputeRat Raceway has a reputation beyond repute
Bubba
It's all up to your Converter maker. You can have a 4l80 converter made for the 4l70 flex plate. This is how mine is. I told Dave at Yank I had an sfi 4l70 flex plate and he made the vert with the right back pads and spacing to work with the existing plate.
Or you can use a 4l80 flex plate with a spacer and use a 4l80 vert.
Hope this helps.
.....TBSS 11.02@ 123mph 7000DA..............
Old Jan-22-12, 07:34 AM   #4
not quick
Dustin is my BITCH
not quick's Avatar
Real Name: Jay
Member # 9298
Casino cash: $947524
Rep Power: not quick has a reputation beyond reputenot quick has a reputation beyond reputenot quick has a reputation beyond reputenot quick has a reputation beyond reputenot quick has a reputation beyond reputenot quick has a reputation beyond reputenot quick has a reputation beyond reputenot quick has a reputation beyond reputenot quick has a reputation beyond reputenot quick has a reputation beyond reputenot quick has a reputation beyond repute
There is .400in spacer on the factory 4l80 flex plate. I think they offer the hybrid incase you already have a good/sfi flex plate.
Old Jan-22-12, 07:36 AM   #5
not quick
Dustin is my BITCH
not quick's Avatar
Real Name: Jay
Member # 9298
I have a 4l80 flexplate. If you want I can press out the spacer and send it to you if you think it will help.
Old Jan-22-12, 08:14 AM   #6
devus1
devus1's Avatar
Real Name: bubba
Member # 1713
Originally Posted by Rat Raceway View Post
Bubba
Hope this helps.
Thanks for the offer jay but if dave can just make it to fit the 4l70 I would rather do that.
Ross dave is going to be doing the converter for this one since I've had great luck out if his products in the past.
AKA "LIFT QUEEN"
Old Jan-22-12, 09:48 AM   #7
Rat Raceway
Real Name: Ross
Member # 61
Your set then. Just tell Dave what you want and he will make it happen.
Old Jan-22-12, 11:04 AM   #8
devus1
devus1's Avatar
Real Name: bubba
Member # 1713
Has anyone one tried the monster transmission 4l80?
AKA "LIFT QUEEN"
Old Jan-22-12, 03:00 PM   #9
jpracing01
jpracing01's Avatar
Member # 1708
Casino cash: $392649
Rep Power: jpracing01 is a splendid one to beholdjpracing01 is a splendid one to beholdjpracing01 is a splendid one to beholdjpracing01 is a splendid one to beholdjpracing01 is a splendid one to beholdjpracing01 is a splendid one to beholdjpracing01 is a splendid one to behold
Bubba
Hope this helps.
this is what i did
just your average run of the mill TT Trailblazer
Old Jan-23-12, 03:09 AM   #10
Nutty Professor
My Student Worker
Nutty Professor's Avatar
Real Name: Britt
Member # 3230
Casino cash: $225200
Rep Power: Nutty Professor will become famous soon enough
Bubba,
Here's the flexplate Left Coast and I are running. It's the 4l80 design and carries the SFI spec. Dave at Yank designed my 4l80 SC3000 converter to utilize the wide 6 bolt pattern on this flexplate (unlike the 3 bolt pattern for the 4l70 flexplate). He considers the 6 bolt pattern a heavy duty design. If your running big HP, I'd recommend this. Yes, you'll still have to run the spacer that comes with the flexplate.
http://www.summitracing.com/parts/TCI-399754/
Built by Duttweiler, Tuned by Left Coast '32
Old Jan-23-12, 03:28 AM   #11
scooter k
scooter k's Avatar
Real Name: Scott
Member # 3313
Casino cash: $225800
Rep Power: scooter k will become famous soon enough
They are definitely a lot cheaper price then others. Like to know how well they hold up!
Old Jan-23-12, 04:35 AM   #12
dep
Real Name: Brian
Member # 12799
Casino cash: $101500
Rep Power: dep is on a distinguished road
Bubba-
I have a 4l80 with a hybrid converter made for a 70 flex plate. When I put tranny in, Id thought I'd order up a TCI sfi flex plate from summit similar to one listed above--which I did. It came with a crank pilot adt which tci said not to use on my application since I had a 70 converter. All went together fine, spacing seemed all good. When I got it running, had a wicked vibration at 3000 rpm, even in park. Tore it back apart and put stock flex plate in (based on Greg and Joe's advice) and amazing--no vibration. I still don't know for sure what caused it,but double and triple check everything you do is balance right and made for eack other--unless you like laying on your back!!!!!
LEP forged LS3-WCCH LS3 Heads-TVS 2300-T-Mac/I.W.10% overdriven-2.9 pulley-Kook's-3" duals-Phoenix 4l80-3200 stall-Circle D Billet Flex Plate-4" FWI intake-100% meth Alky Control-New 1/4 times coming this spring-10.??!Tuned by "Left Coast 32"
