May-13-12, 10:12 PM
#1
DIY
Real Name: Tony
Member # 16639
Where do I go next??
Just finished the basic stuff (K&N, NGK TR6's, 8.5 MSD wires, Optima battery and Flomaster exhaust. What do I do next? I am picking up a 160 thermostat tomorrow although I'm hesitant since I live in the Chicago area. I don't want to drop a $1000 on my next upgrade. I'd like to do something mild yet beneficial. Any ideas guys/gals?
May-13-12, 10:18 PM
#2
Real Name: Dustin
Member # 7804
If you are doing the thermostat I'd also do efans while you are at it. Those two mods go together like porn and lotion.
"The bitterness of poor quality remains long after the sweetness of low pricing is forgotten"
May-13-12, 10:21 PM
#3
DIY
Real Name: Tony
Member # 16639
E-fans huh? Any recommendations? 02 Firebird type or something aftermarket?
May-13-12, 10:27 PM
#4
Real Name: Dustin
Member # 7804
http://www.tbssowners.com/forums/showthread.php?t=79194
Hit up pcmforless for the wiring harnes and to ask them any questions you might have.
May-13-12, 10:52 PM
#5
DIY
Real Name: Tony
Member # 16639
Thanks man.
May-19-12, 08:44 PM
#6
DIY
Real Name: Tony
Member # 16639
I just ordered the 160 tonight. I don't have enough right now to do the fans and SLP says I don't need a tune to make the stat work ok without throwing codes. I also bought new battery cables to fix the dimming headlight problem. Need to get my electrical system sound before adding to it and I need to save a few more bucks before the efans can get ordered.
May-19-12, 09:50 PM
#7
Real Name: Matt
Member # 5229
save your money and buy a stall next. that is "BY FAR" the best bang for the $ mod you can do. you will not believe the difference its like driving a totally different car.
06 2wd TBSS H/C/I 6.0 474/432
All Motor Record holder 1.54 60', 11.34 @ 116.86
May-19-12, 09:55 PM
#8
DIY
Real Name: Tony
Member # 16639
I've heard that but I tow with my truck every weekend and sometimes I pull a 4500lb boat. I heard also that the stall screws up the towing abilities. Any experience with towing after getting a stall?
May-27-12, 08:18 PM
#9
Real Name: Mike
Member # 11268
4500lbs is a big ass boat
Cold Air Inductions intake, Magnaflow cat-back w/ res delete, Fast Motorsports Stg 1 tranny kit, cooler and tuned TCM, Spal efans, 160 Stat, PCMforLess Big 3 cable upgrade, Aeroforce, DJM front drop and Belltech drop springs and shocks out back, Full custom audio.
May-27-12, 08:26 PM
#10
Real Name: Matt
Member # 5229
call yank, they make stalls that you can still tow with. just call them he will tell you what you need. great guy
May-27-12, 09:33 PM
#11
DIY
Real Name: Tony
Member # 16639
Well, its an 18ft Nitro Z7 with a 150hp motor and the trailer is pretty beefy too. My dad said it was around 4500lbs but I'm going to look into it now that you said something cause that does sound heavy. All I know is that I felt it back there. lol.
-07 1SS AWD Black/Black | Dorman efans FAST wired, SLP 160stat |TR6 plugs, 8.5MSD wires |ieatsrt8 CAI w/pcm breakout harness & headlight mod |FAST tune/Dashhawk |pcm trans cooler |Catch can |Catless, Magnaflow |Brakemotive drilled/slotted.
May-27-12, 09:38 PM
#12
Real Name: Jason
Member # 3320
Never heard it put that way, but that is quite comical!
May-27-12, 09:39 PM
#13
DIY - King a destruction
Real Name: Walter
Member # 12143
Has it been tuned for the CAI and exhaust. If not, then do that before the fans. If the funds are there for a stall or sonnax shift kit, thats next. Tune can be worth .3-.4 if you havent done it, more if your truck was slowed down by the bolt ons. Stall in an AWD is .6 at least, a little less for 2WD. G/L with the mods!
6.0 AWD ~ T88 Turbo ~ 60mm Gate ~ 50mm BOV
Diamond Pistons ~ Eagle Crank & Rods ~ Superchilled
Billet 4L80 ~ 4000 Stall Billet Converter
May-27-12, 10:04 PM
#14
Canadian
Real Name: Ryan
Member # 5308
If you got a spare $2000 I got this guy ^ that can show you how to bow-jack your ride
2006 Black AWD TBSS Jetttstream stage 3 CAI w/ AEM dry flow filter, Diablosport,160TStat,'07 wiper, vinyl overlays, servos, tranny cooler, Magnaflow 12259 w/ res. delete, 35% tint front, de-badged, billet bowtie, AMI 15'' antenna, LED reverse lights, Optima Red top w/ billet hold down, Nitto 420s, Hotchkis swaybar
May-30-12, 08:53 PM
#15
Real Name: David
Member # 13292
Dorman E-fans from any auto parts store for a Camaro/Trans Am and the PCM4Less harness are all you need.
And bang-for-the-buck as far as fun in driving the truck and overall performance improvement, a torque converter is definitely the way to go. And don't let anyone tell you you can't tow with a higher stall speed converter
07 TBSS - some mods
May-30-12, 10:39 PM
#16
Real Name: Brian
Member # 7652
Talk to huronspeed or Dave at yank they can get you a converter that you can still tow with. Just make sure you get a transcooler.
2007 AWD| Forged 402 | AFR heads | RPM level V | kooks 1 3/4 with ory/cats | ieatsrt8 intake | pcmforless transcooler | efans | circle D 3200 | R1 slotted rotors | SS braided brake lines |
May-30-12, 11:27 PM
#17
DIY
Real Name: Tony
Member # 16639
Trans cooler is a must for towing with a yank, I assumed that much. Today my RPM's went right through the red on the way onto the highway (2nd gear). Scared me a bit, pooped a little, but I couldn't get it to repeat itself so I don't know what to think. Def don't want to blow the coin on a stall when my tranny might be acting like a shit-stain in brown undies.
Jun-06-12, 12:36 PM
#18
Real Name: Matt
Member # 5229
mine did that "once on the interstate" a long time ago it was weird but never did it again.
Jun-06-12, 12:44 PM
#19
Real Name: Walter
Member # 12143
Someone had a used Yank on here for $600 if that is in the budget. I know you didnt want to spend a $1000, but that will make the biggest bang for buck. Especially over the e-fans.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
