Jun-12-12, 05:39 PM
#1
Member # 9166
Amp goes into protect.
Hi,
i have everything tuned properly with a voltage meter but when i turn to full volume no matter what the amp will go into protect.
i have a
2007 tbss 3ss
bose is still in with pac aoem-gm24 i think it been in there a while.
just wondering if i am doing something wrong or is this something the bose amp is doing and causing this to happen?
Jun-12-12, 05:42 PM
#2
Real Name: jason
Member # 8071
Maybe not getting enough power. Amp could b clipping causing it to go into protection
Jun-12-12, 05:56 PM
#3
Member # 15513
Status:
Online
Your running the amp into protection due to ohms, could be bridging the speakers and the amp not being able to go that low
Amp model / speakers ohm dual or single voice coil
Jun-12-12, 05:59 PM
#4
Member # 9166
AudioPipe APSM1300
sundown sa 10 d2
wired to 1 ohm for 1000rms.
Jun-12-12, 09:23 PM
#5
Real Name: Shelton
Member # 6438
Wire it for 2 ohm and see what happens. I'd bet the amp doesn't stay stable at 1 ohm.
Jun-12-12, 10:09 PM
#6
Real Name: Mike
Member # 15957
Status:
Online
APSM-1300
Channels 1 Channel
Power (P.M.P.O) 1000 Watts
Power (R.M.S) 300W @ 4 Ohm
600W @ 2 Ohm
1000W @ 1 Ohm
Says its 1-ohm stable. Do like Truckshop said and wire it @ 2ohms. May be the amp itself. What size power/ground are you running? Are they the same size? I've seen people put a larger power than ground, or vice-versa and create issues. Good luck.
Originally Posted by ForceFed
I'll continue to stick by my motto.....
Don't Talk about it, Be about it.
Jun-14-12, 08:26 PM
#7
DIY - King a destruction
Real Name: Walter
Member # 12143
Check the ohmage with a good quality digital meter. Test it both at the speaker, and then at the wires (with them disconected at the amp. You will get a tad higher reading through the wire usualy, even with good wires. My guess is your under the 1ohm. Either that or you have the gains too high and are clipping, or the amp is getting too hot. Does it do it right away, or after jamming for a while?
6.0 AWD ~ T88 Turbo ~ 60mm Gate ~ 50mm BOV
Diamond Pistons ~ Eagle Crank & Rods ~ Superchilled
Billet 4L80 ~ 4000 Stall Billet Converter
Jun-14-12, 09:15 PM
#8
Real Name: Jon
Member # 5717
Check your grounds, make sure your gains are set. I hope you have quality 4 gauge feeding that amp.
2007 Trailblazer SS AWD - PCMforless Tune | LS1 e-fans | 4" intake w/ LS7 MAF | 160 thermostat | Powerbond UD Pulley | NGK TR6 plugs | Catless y (stock) | Magnaflow 11229 | trans cooler
Jun-15-12, 04:40 AM
#9
Founding Member!
Real Name: Mike
Member # 3
Well, the suggestion to wire it for 2 ohms will not work since it is a Dual 2 ohm driver. He could wire it for 4 ohms and test the amp that way. It could also be an internal issue with the amp. Check this thread out on DIYMA.com: http://www.diymobileaudio.com/forum/...sign-flaw.html
MikeG
I'm Back!
Jun-19-12, 06:18 PM
#10
Member # 9166
Yeah i moved the power from the fuse box to the battery right now and i am going to test it out when my new sub gets here.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
