Go Back   TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum > TBSS Modifications > Power Adders > Superchargers and Turbos
Superchargers and Turbos From Maggies To Kenne Bell To STS
Old Jun-20-12, 04:44 PM   #1
dmaxvaz
Member # 13264
Casino cash: $109600
Rep Power: dmaxvaz will become famous soon enough
Default fuel system for boosted tbss
I am gathering parts for a mild turbo build, and was wondering if the stock fuel pump will be good enough. I will start with 8 psi boost, and work up to 10psi. Would you guys reccomend the 42 lb green injectors and a kb bap? I am also doing 317 heads, and Ls9 cam. My hp goal will be 550ish. The turbo is a bb 76mm turbonetics with a 1.0ar. I am also considering water meth if need be.
Old Jun-20-12, 05:03 PM   #2
northjerseySS
RoyalT
Real Name: Ryan
Member # 10113
Casino cash: $132600
Rep Power: northjerseySS will become famous soon enough
KB bap is a bandaide from what I hear, your gonna have to upgrade the pump and pretty sure everyone runs 100% meth
402 stroker,trickflow heads,custom cam,AR LT's,off road y,corsa sport,pcmforless intkae,ls7mafs,level6 trans,circled 2800 stall, tranny cooler, street tune
Old Jun-20-12, 05:47 PM   #3
dmaxvaz
Member # 13264
Would a stealth 340 work ? Sorry, I was thinking diesel with the water meth idea. Meth it will be.
Old Jun-20-12, 06:35 PM   #4
gn2beatu
DIY - King a destruction
gn2beatu's Avatar
Real Name: Walter
Member # 12143
Casino cash: $498800
Rep Power: gn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond repute
Walbro 400 flows more, and is cheaper. I can barely run 14psi on E85 and thats it. At 10psi you will be fine. Get the one on ebay with the install kit. It has the line, clamps, and sock. I have the LS9 cam as well, and mild home port job on the stock heads. Im using 85-90% duty cycle on FIC 1000cc injectors rated at 3bar. 105lb at 3bar is 125lb at 4bar. No way in hell 42lb injectors will work at 10psi. Get at least the 60lb injectors. If E85 is available I would do that instead and go bigger in injectors. Trust me on this, I just when through all this on my build. I could only run 6 degrees of timing on 93 octain and no meth at 6400rpm, and only 2 degress at 4800 rpms. You may get away with more at 10psi, but trust me E85 is the shiznit. You can get FIC 1000 injectors for like $600. Skip the cost of the meth, and put the money in injectors so you can run more boost. You will be addicted. The T76 is a great turbo, but compressor wise its out of breath at 16psi. Not sure how far your goona push it down the road, just thought Id let ya know. I did the Godspeed T88 for $450 on my build. You can find more info on my build thread, if you can wade through 70 pages of comments for the 30 pages of info. G/L
6.0 AWD ~ T88 Turbo ~ 60mm Gate ~ 50mm BOV
Diamond Pistons ~ Eagle Crank & Rods ~ Superchilled
Billet 4L80 ~ 4000 Stall Billet Converter
Old Jun-20-12, 06:51 PM   #5
devus1
devus1's Avatar
Real Name: bubba
Member # 1713
Casino cash: $560480
Rep Power: devus1 has a brilliant futuredevus1 has a brilliant futuredevus1 has a brilliant futuredevus1 has a brilliant futuredevus1 has a brilliant futuredevus1 has a brilliant futuredevus1 has a brilliant futuredevus1 has a brilliant futuredevus1 has a brilliant futuredevus1 has a brilliant futuredevus1 has a brilliant future
. lonnies double pumper
Old Jun-20-12, 08:06 PM   #6
deenasty
deenasty's Avatar
Real Name: Diego
Member # 236
Casino cash: $130500
Rep Power: deenasty will become famous soon enoughdeenasty will become famous soon enough
Im running the same turbo you are running, with a slightly larger AR. I am still on a stock pump with no issues. I will be upgrading soon, for the peace of mind.
2006 SILVERSTONE 2WD, Turbo...550/580 SOLD!
2011 CTS-V.
Old Jun-20-12, 08:28 PM   #7
lt1z
illegitiminoncarborundum
lt1z's Avatar
Real Name: Matt
Member # 64
Casino cash: $1522800
Rep Power: lt1z has a reputation beyond reputelt1z has a reputation beyond reputelt1z has a reputation beyond reputelt1z has a reputation beyond reputelt1z has a reputation beyond reputelt1z has a reputation beyond reputelt1z has a reputation beyond reputelt1z has a reputation beyond reputelt1z has a reputation beyond reputelt1z has a reputation beyond reputelt1z has a reputation beyond repute
Meth helps a lot in that regard.
08' C6 M6 743/647
93' Z28 A3- in pieces
06' RCSB H/C
Old Jun-20-12, 08:33 PM   #8
Grocery Getter
Grocery Getter's Avatar
Real Name: Mike
Member # 15957
Casino cash: $286672
Rep Power: Grocery Getter has much to be proud ofGrocery Getter has much to be proud ofGrocery Getter has much to be proud ofGrocery Getter has much to be proud ofGrocery Getter has much to be proud ofGrocery Getter has much to be proud ofGrocery Getter has much to be proud ofGrocery Getter has much to be proud ofGrocery Getter has much to be proud of
Originally Posted by ForceFed View Post
I'll continue to stick by my motto.....
Don't Talk about it, Be about it.
Old Jun-20-12, 08:36 PM   #9
Grocery Getter
Real Name: Mike
Member # 15957
Oh, sorry, you said meth
Old Jun-20-12, 08:45 PM   #10
1 Fast TB
Daddy's Here to Race
1 Fast TB's Avatar
Real Name: John
Member # 15620
Casino cash: $173633
Rep Power: 1 Fast TB is a glorious beacon of light1 Fast TB is a glorious beacon of light1 Fast TB is a glorious beacon of light1 Fast TB is a glorious beacon of light1 Fast TB is a glorious beacon of light1 Fast TB is a glorious beacon of light
For the cost of lonnies double pumper you can add a little bit more to it and have IPS Motorsports build you a better setup like I have in mine now.
http://www.tbssowners.com/forums/showthread.php?t=80041
06 White roller for sale soon.
08 Red AWD 370 LEP, All Pro, Jack/Shaft TVS2300, E85, FLT 4L70, 3200 Yank **9's on the way**
Old Jun-20-12, 09:20 PM   #11
dmaxvaz
Member # 13264
How big of injectors are you using? And are you using the stock returnless fuel system, or do you have a boost reference regulator? Is your turbo a front mount? Are you using a bap? Sorry for all the Q's. Thanks for all info
Old Jun-21-12, 01:21 PM   #12
devus1
devus1's Avatar
Real Name: bubba
Member # 1713
I dont see any benfit to the IPS system? Looks like a single pump system from the picture?
Im not for sure if the IPS system would support what im doing with mine...but your welcome to educate me on it..
Old Jun-21-12, 01:37 PM   #13
1Baddz
Real Name: Jesse
Member # 16142
Casino cash: $70434
Rep Power: 1Baddz is on a distinguished road
Use the Ford Bosch m9593g302 injectors. They are ample (56#) for what you're doing and have the same plug as your stocker as well as being the same height. you won't beat them for the cost, they can be had for under $300 new. The Aeromotive stealth will be fine, you don't want to overdo it on the fuel pump, that actually causes pump failures and overheated fuel. If 10psi is truly your final goal, there's no reason to go bigger than those two.
Old Jun-21-12, 01:54 PM   #14
Jeremy@HOB
Jeremy@HOB's Avatar
Real Name: Jeremy
Member # 7920
Casino cash: $84300
Rep Power: Jeremy@HOB is a jewel in the roughJeremy@HOB is a jewel in the roughJeremy@HOB is a jewel in the roughJeremy@HOB is a jewel in the rough
The A1000 in his kit will support 1000hp in a boosted application. If you need more then the next step up to the Eliminator pump will support 1200hp in a boosted app.
Makers of the BEST centrifugal supercharger system available for the TBSS
Be sure to follow us on Facebook - House of Boost
Old Jun-21-12, 02:08 PM   #15
devus1
devus1's Avatar
Real Name: bubba
Member # 1713
I would rather have to much the 1st time then get on the dyno and run out.......I would be scared with the system he has from IPS it would not be enough.
Old Jun-21-12, 05:11 PM   #16
dmaxvaz
Member # 13264
Anybody know if the walbro 400 lph pump will fit in the stock bucket?
Old Jun-21-12, 05:41 PM   #17
devus1
devus1's Avatar
Real Name: bubba
Member # 1713
Somebody has used this pump...let me see if I can find it.
Old Jun-21-12, 06:39 PM   #18
Sleezy E
moar cowbell
Sleezy E's Avatar
Real Name: Eric
Member # 3039
Casino cash: $645000
Rep Power: Sleezy E has a reputation beyond reputeSleezy E has a reputation beyond reputeSleezy E has a reputation beyond reputeSleezy E has a reputation beyond reputeSleezy E has a reputation beyond reputeSleezy E has a reputation beyond reputeSleezy E has a reputation beyond reputeSleezy E has a reputation beyond reputeSleezy E has a reputation beyond reputeSleezy E has a reputation beyond reputeSleezy E has a reputation beyond repute
That's what gn2beatu (Walter) is running so... Yes.
'06 5.3l turbo TB
'01 c5z
Old Jun-21-12, 07:10 PM   #19
dmaxvaz
Member # 13264
Let me rephrase that. I meant if the walbro 400 fits in the stock bucket without hacking it up. Is it a direct fit is what I'm asking. I've read that it isn't in like GTOs and stuff like that.
Old Jun-21-12, 07:57 PM   #20
1 Fast TB
1 Fast TB's Avatar
Real Name: John
Member # 15620
Why would you think this fuel system would not support what you are wanting to build. This pump is the best pump on the market right now. If the 1000 is not enough then the 1000 eliminator would be more than enough.
You would need a custom fuel hat to use this pump and run a return fuel line back to the tank.
Im running E85 with 1100cc injectors on 15lbs of boost and the fuel pressure does not drop.
