Jun-26-08, 07:17 AM
#1
Real Name: Caleb
Member # 142
2nd Summertime Norwester GTG time!
Despite the irony that the guy working 7 days a week and failing at owning an SS is suggesting this, but I am.
The weather here has finally granted us the pleasure of what we call summer (known typically as raining less than 3 days a week), and with the multiple new additions, including Joe's Turbo, a few tunes, Doug's near 11 second SSS, Duff's new LS3, etc. etc., I think it's time we found a way to show this new gear off.
I know there are a couple people who would like to get track times and tweak their tunes as well, which I think would be great fun, if we can find a good location.
Now, as for dates and locations, discuss. I'm down for traveling, fwiw.
DISCLAIMER: I'm a bit tipsy, so if anything here seems unclear, perhaps I should just go fuck myself.
Jun-26-08, 07:48 AM
#2
Member # 781
anywhere anytime except for August 16th (Daughters 1st Birthday)
2007 White AWD - SOLD 2009 Stryker Blue Pontiac G8 GT - SOLD 2007 Yukon Denali - Daily Driver Soon to have CTS-V
Jun-26-08, 08:58 AM
#3
Real Name: Caleb
Member # 142
Well, that's a good reason...I guess I can append I will be in Disneyland on 8-1  .
Brad, are you doing your own HPT stuff yet? I know you talked about it before.
Jun-26-08, 10:28 AM
#4
Member # 781
Not yet... trying to get the tranny done first. Should be soon just trying to decide what route to go.
Jun-26-08, 11:31 AM
#5
Real Name: Caleb
Member # 142
I suggest a route that makes you go faster. You might find out who did Doug's, as I think it was local, and that thing is tough.
Jun-26-08, 09:11 PM
#6
Real Name: Nate
Member # 472
I'm pretty open at this point.
Jun-26-08, 10:02 PM
#7
Real Name: Joe
Member # 82
I am open, the only thing I have planned is getting my TBSS running. I am getting close... so close I can almost smell the exhaust and hear the turbo spooling...
2006 AWD, All blacked out, Lowered 1-3/8"
416ci stroker, STS 76MM TURBO, water/meth injection, 1-3/4" Kooks LT, E-fans, 160 T-STAT, P&P LS7 TB, U/D pulley, 3200 Vig. and built transmission with cooler.
13.20 at 102 MPH Before sts turbo
12.34 at 111 MPH with turbo then the engine blew!!
11.76 at 115 MPH 416ci on 10 PSI
Jun-27-08, 05:56 PM
#8
Real Name: duff
Member # 411
mine should hopefully be ready by 4th of july weekend.
gone but not forgotten:2007 tbss awd,ls3,procharger d1sc,3.4" pulley,meth,10+ lbs boost,overdrive crank,cartek flip-drive,rpm trans,yank ptb 3600,wireless air,29 7/8" all around,six jl audio 12"w3 subs, 15.4" drop-down dvd player
Jul-03-08, 01:16 PM
#9
Member # 781
what ever happened with your cam issue??
Jul-03-08, 06:48 PM
#10
Real Name: duff
Member # 411
im just going to let it go. if i let them order the cam i would be all over it. this company i found out later has a bad reputation and not standing by their work. they would just tell me it was cam that caused the failure. my block has a hole a loaf of bread could fit through on the passenger side. on the drivers side it looks like i punched two holes through the block with my fist. the installer of my new motor said it was the 2nd worst blown motor he has ever seen, the other was a track only motor. my installer had a infected tooth, his jaw swelled up. he has not really worked on my truck for a couple days. hopefully i will get a base tune next wednesday, break in the motor then dyno tune down in auburn somewhere on a awd dyno.
Jul-04-08, 08:56 AM
#11
Real Name: Caleb
Member # 142
Is that Speed Secrets dyno? They do good LS2 work...so does Blood, but both are pricey.
There is an AWD dyno in Ballard that fits a TBSS, and also one in Redmond. I use the guys in Ballard...$125 for 3 runs and a 1/4 mile on a Mustang dyno.
Keep us posted.
Jul-04-08, 06:51 PM
#12
Real Name: duff
Member # 411
yeah i know, nothing is cheap. i also ended up staying with my yank ss4000 stall so it will probably dyno less hp than if i had a lower rpm stall. although, i will be faster out of the hole.
Jul-29-08, 06:19 AM
#13
Real Name: Caleb
Member # 142
Bump...Joe is running, and getting dialed in next week...Duff?
Jul-29-08, 03:15 PM
#14
Real Name: Nate
Member # 472
If we get a date I may be able to make it. I'll be working over in Silverdale for about 3 mos. and could take the SS one week.
Jul-29-08, 08:32 PM
#15
Real Name: duff
Member # 411
i have been driving it took it back for 1000 mile oil change. small tweaks here and there. replace bad o2 sensor, check for exhaust leaks. trifecta performance is the one that is dialing in my tune. at the dyno was having trouble with the abs kicking in. went with a rolling tune.
Jul-30-08, 08:27 AM
#16
Real Name: Caleb
Member # 142
Any objections to 9/6? We'll find a location halfway between Seattle and Portland?
Jul-30-08, 10:43 AM
#17
Member # 781
Im down for whatever whenever...
Jul-30-08, 04:56 PM
#18
Real Name: Nate
Member # 472
That works for me as far as I know. What kind of locations are you guys considdering?
Jul-30-08, 08:08 PM
#19
Real Name: Joe
Member # 82
That works for me.
Jul-30-08, 09:08 PM
#20
Member # 781
theres a burgerville in centralia..... I love that place
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
