service stabilitrak message? - TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum
Go Back   TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum > TBSS Drivetrain > 4L70E Transmission Help
4L70E Transmission Help Tranny Info and Upgrades including torque converters (stall)
Old Nov-10-08, 05:51 AM   #1
TrueLS2
Real Name: SHawn
Member # 1038
Casino cash: $196150
Like: 0
Liked 0 Times in 0 Posts
Rep Power: TrueLS2 is an unknown quantity at this point
Default service stabilitrak message?
this morning I got a service stabilitrak message on my display. What causes this cause the truck seems to be driving fine. I'm also worried about bringing it in for service and having my tune erased. What would you guys do. Thanks
06 Awd Cam+bolt ons Slowhawk Performance tuned.
12.49 @ 107mph with 1.76 60'
Sponsored Links
Advertisement
Old Nov-10-08, 06:17 AM   #2
rrmccabe
aka RADIO SHACK
rrmccabe's Avatar
Real Name: Rich
Member # 243
Casino cash: $624790
Like: 101
Liked 285 Times in 137 Posts
Rep Power: rrmccabe is a splendid one to beholdrrmccabe is a splendid one to beholdrrmccabe is a splendid one to beholdrrmccabe is a splendid one to beholdrrmccabe is a splendid one to beholdrrmccabe is a splendid one to beholdrrmccabe is a splendid one to behold
What are your mods?
Exceeding torque values can do it but that usually only happnes when you start making big power. When did it happen? WOT?
Old Nov-10-08, 07:05 AM   #3
JFB423
JFB423's Avatar
Real Name: Joe
Member # 455
Casino cash: $53345
Like: 0
Rep Power: JFB423 is an unknown quantity at this point
Here is a TSB
#08-05-25-005: Intermittent StabiliTrak Indicator Light Blinking, StabiliTrak Active Message Displayed, DTC C0196 Set (Reprogram Electronic Brake Control Module (EBCM)) - (Oct 1, 2008)
Subject: Intermittent StabiliTrak® Indicator Light Blinking, StabiliTrak® Active Message Displayed, DTC C0196 Set (Reprogram Electronic Brake Control Module (EBCM))
Models: 2006-2007 Buick Rainier
2006-2009 Chevrolet TrailBlazer Models
2006-2009 GMC Envoy Models
2006-2009 Saab 9-7X
2006-2009 Isuzu Ascender Models
This bulletin provides information on two different conditions.
Condition #1
Some customers may comment on a Service StabiliTrak® indicator light along with a Service StabiliTrak® message displayed in the DIC. Upon investigation, the technician may find DTC C0196 set in history.
Condition #2
Some customers may comment on a blinking StabiliTrak® indicator light along with a StabiliTrak Active message displayed in the DIC during normal driving conditions. No DTCs will be found with this concern.
Cause
This condition may be caused by a software anomaly within the electronic brake control module (EBCM) that allowed the yaw offset to be falsely learned.
Correction
Do This
Don't Do This
Reprogram the EBCM.
Do not replace the yaw sensor or EBCM for this condition.
Important: From the controller list, select "VSES Vehicle Stability Enhancement System Control Module."
If routine diagnosis using SI does not reveal any obvious cause, reprogram the EBCM using SPS with the latest software available on TIS2WEB. Refer to the Service Programming System (SPS) procedures
06 AWD/Dual Ram-Air intake/TB spacer/Magnaflow catback/R-1 rotors/Addco Sways/160 stat/C-6 E-Fan w/pwm controller/ Tuned by CORVETTES OF WESTCHESTER
13.36 @102.91
Old Nov-10-08, 07:29 AM   #4
TrueLS2
Real Name: SHawn
Member # 1038
Like: 0
I'm pretty much stock other then exhaust and tune. Im worried about them relearning my PCM and losing my tune. This also turned on under reguler driving on the highway.
Old Nov-10-08, 07:41 AM   #5
DVelasco68
DVelasco68's Avatar
Real Name: David
Member # 469
Casino cash: $365800
Like: 0
Liked 9 Times in 9 Posts
Rep Power: DVelasco68 is a jewel in the roughDVelasco68 is a jewel in the roughDVelasco68 is a jewel in the roughDVelasco68 is a jewel in the rough
dvelasco68
Just find and pull the fuse, I did that on my wifes car (not a TBSS but GM) two years ago, and have never seen it pop up again...
All is working fine.... (You could alternately disconnect the battery for a while.)
2007 AWD Summit White - 3SS (13.74@100.31) - daily driver
1987 T-Type (12.10 @ 111.5) - in the garage
1986 Grand National (13.29 @ 101.5) - stolen
Old Nov-10-08, 07:54 AM   #6
SSSkach
SSSkach's Avatar
Real Name: Dave
Member # 94
Location: Bentonville Arkansas Home of NO TUNERS or DYNOS!
Casino cash: $342180
Like: 0
Rep Power: SSSkach will become famous soon enough
Otherwise ya gotta have them re-program the ecm
06 AWD, Maggie 112, Kooks Long Tubes,SLP Duals,Vector Tune & E-fans, Left Coast Joe 4" Maggie CAI, Cold Air Inductions Fresh Air Box, Phoenix built Trans & Stall, Trans Cooler, Race Mesh Grille,Clear Lights, LED Tails, Chromed Stockers, Slotted Rotors,Ceramic Pads & Functional Ram Air Hood!!!
WHEN IN DOUBT--BOOST IT OUT!
Old Nov-10-08, 07:55 AM   #7
TrueLS2
Real Name: SHawn
Member # 1038
Like: 0
thanks I'll try that
Old Nov-10-08, 06:18 PM   #8
Ohnoitsa60
Ohnoitsa60's Avatar
Real Name: Jake
Member # 184
Casino cash: $130099
Like: 0
Rep Power: Ohnoitsa60 is an unknown quantity at this point
what tune???
I ad that problem with a Westers tune
www.boltonspeed.com
Old Nov-11-08, 08:03 AM   #9
TrueLS2
Real Name: SHawn
Member # 1038
Like: 0
pcmforless tune. Got in the truck after work and there is no more message? Guess that's a good thing.
Old Nov-11-08, 09:06 AM   #10
callonit
callonit's Avatar
Real Name: mike
Member # 1459
Casino cash: $243800
Like: 0
Rep Power: callonit will become famous soon enough
same happen to me like 3 days ago just going to the store....i looked down and saw the message tried to push the putton and it didnt work....got to the store cut it off and cutit back on message has not poped up sence...and i have not tried to see if it works yet...my truck is in the body shop as soon as i get it out i will check it.....
mods: hp tune by 262,ieatsrt8 CAI & RLK,deleted resonator,160 thermostat,lt1 e fans, powerbond ud pulley, 262 tranny cooler, phoenix 3200,kooks y pipe to stock exhaust, dr 17" best/no stall 13.21 @ 103.7 60' 1.963 soon. gt 11 cam, nos 100shot, electric cutout, , and black pc stock rims
Old Nov-11-08, 03:30 PM   #11
TrueLS2
Real Name: SHawn
Member # 1038
Like: 0
Mine did the same as you i had no control over it via the switch when the message was on. I just tryed turning it off on the way home and all is working fine. Kinda wierd.
Old Nov-11-08, 05:30 PM   #12
JAY4SPEED
JAY4SPEED's Avatar
Real Name: Jay
Member # 2356
Casino cash: $435530
Like: 0
Liked 2 Times in 2 Posts
Rep Power: JAY4SPEED has a spectacular aura aboutJAY4SPEED has a spectacular aura aboutJAY4SPEED has a spectacular aura about
When the light goes out and message is gone, that means that the conditions that caused the DTCs are no longer present. The codes are however stored in history in the EBCM for quite a few ignition cycles. See if Onstar can read the code(s) and post them up.
Originally Posted by ForceFed View Post
Sometimes when you stray away from the "Tried and True" you become the guinea Pig for the Pack.
Old Nov-13-08, 08:53 PM   #13
Sedg
007 SS - AWD
Sedg's Avatar
Real Name: Steve
Member # 1750
Casino cash: $90555
Like: 0
Rep Power: Sedg is an unknown quantity at this point
Sedg
I had the Service Stabilitrak show up and have been able to duplicate it.
If you happen to be pulling away with a fair bit of throttle/corner exit while in the process of holding the STRAK button (to disengage) you will likely get the Service Stabilitrak displayed. I have had it happen 3 times now and everytime I shut the vehicle down it resets itself.
I just figured the truck had trouble chewing on the wheel slip/yaw data while I was attempting to disengage STRAK.
Back on the road one day...
Built 427LSX, suspension, trans, etc. etc.
Damn build takes 3x as long as you plan and costs 3x as much.
