Hey Guys,
I uploaded these intakes to our website. This should save you guys some money.. Why? Because to build these you have to buy from at least 3 different places and you can run up shipping cost quick. I put it together as a "DIY" package that should be cheaper than you can buy it on your own.
If your interested in duplicating this yourself and do not want to get the parts from me, I totally understand. Here's what I used in my kit
1 K&N filter K&N RE-0870
1 Piece of 7" pipe from intakehoses.com
1 4 inch MAF sensor (LS7 style, with connector. It will not plug into the factory harness without the connector)
2 45 degree silicone 4 inch from siliconeintakes.com
1 90 degree silicone 4 inch from siliconeintakes.com Replace with 4 inch x 3.75 if reusing stock MAF
1 45 degree Aluminum elbow from intakehoses.com
6 4 inch hose clamps.
I'm selling it all as a complete package including MAF sensor for $360. The MAF's only for $172.13. $360 might sound expensive but we are including a new 4 inch MAF sensor. I've sold the stock 85mm MAF on ebay before between $85-$125. Our stock MAF sensor is a really popular upgrade for 98-00 vettes, 98-02 camaros, and 2000 and earlier trucks.
http://www.pcmforless.com/index.php?...d=72&Itemid=86
Some caveats
*IF you make your own 4 inch sensor housing know that a mail order tuner will likely not be able to get the tune correct at least first try. The tune and sensor housing/position is EXTREMELY critical. This is one of the reasons why our price might be higher than you expect. Our housings are made to be within .0015 of a inch AFTER the welding.
*cannot use factory washer tank. We have a simple aftermarket washer tank that mounts both pumps out of the way where you cannot see them.
*requires radically different tuning. Will not even run on tunes not meant for this. If you buy the intake/MAF from us we will give you a start MAF calibration table
*requires removal or at least trimming of factory engine cover
*requires 4.25" hole drilled underneath where the factory washer tank sits.
*Can be made cheaper using rubber elbows but I preferred the nicer/cleaner look of silicone. I have not tried making it out of rubber, so if you do it let us know how it turns out.
*may including powdercoating later, but are not setup to give quotes at this time.
