Go Back   TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum > TBSS Modifications > Bolt Ons > Intakes/MAF/HSRK/IAT
Intakes/MAF/HSRK/IAT Cold Air Intake info
Old Mar-22-10, 08:35 AM   #21
KSHICKS SS
Real Name: Kory
Member # 7031
Casino cash: $104950
Rep Power: KSHICKS SS is an unknown quantity at this point
All has been fine, for almost 3 weeks, now the light came back on. Its throwing code P017 (System too lean bank 1)...anybody??? I really don't know where to start with this one.
07 TBSS 3SS 2WD -- DJM A-Arms / Belltech 796SP Kit / PCMforLess Tranny Cooler - Fan Kit / Cold Air Inductions CAI / 3W Battery Cable Upgrade
Old Mar-22-10, 03:18 PM   #22
KSHICKS SS
Real Name: Kory
Member # 7031
Bump
Old Mar-22-10, 03:39 PM   #23
TWO-TONS-OF-FUN
Powered by Bath Salts
TWO-TONS-OF-FUN's Avatar
Real Name: Greg
Member # 1248
Casino cash: $1969562
Rep Power: TWO-TONS-OF-FUN has a reputation beyond reputeTWO-TONS-OF-FUN has a reputation beyond reputeTWO-TONS-OF-FUN has a reputation beyond reputeTWO-TONS-OF-FUN has a reputation beyond reputeTWO-TONS-OF-FUN has a reputation beyond reputeTWO-TONS-OF-FUN has a reputation beyond reputeTWO-TONS-OF-FUN has a reputation beyond reputeTWO-TONS-OF-FUN has a reputation beyond reputeTWO-TONS-OF-FUN has a reputation beyond reputeTWO-TONS-OF-FUN has a reputation beyond reputeTWO-TONS-OF-FUN has a reputation beyond repute
have a friend that is local to your wife... ( a good one....) swap the stock airbox back in and take it to the dealer...
instead of posting from across the country, remove all variables, and have her take it in.. not only will it be easier for you, but her also....
Old Mar-22-10, 03:56 PM   #24
2sslow
Real Name: alex
Member # 3484
Casino cash: $96500
Rep Power: 2sslow is on a distinguished road
the code just explained exactly what was wrong. along with some of the other members. lean means you are getting too much air, and not enough fuel. rich means you are getting too much fuel and not enough air. the ieatSRT8 intakes are known to be nicer intakes with little to no air resistance. and like another member state some people can install intakes without tune just fine. others have codes pop up. get a tune and the codé should go away for good. if u dont want to get a tuné yet just swap to the stock intake for now. good luck!
Old Mar-24-10, 06:37 AM   #25
ieatsrt8
Member # 297
Casino cash: $259040
Rep Power: ieatsrt8 is just really niceieatsrt8 is just really niceieatsrt8 is just really niceieatsrt8 is just really nice
Our intake will work with the stock programming however there is a chance it will through a lean code under hard wide open throttle driving. The intake does make more power than the stock unit obviously so it does lean out the fuel trims. Typically it is within the range that a CEL will not occur. Based on the lean bank code a performance tune will correct your problem.
02 Z06 "Blue Devil"
Old Mar-24-10, 06:50 AM   #26
rrmccabe
aka RADIO SHACK
rrmccabe's Avatar
Real Name: Rich
Member # 243
Casino cash: $463090
Rep Power: rrmccabe is a glorious beacon of lightrrmccabe is a glorious beacon of lightrrmccabe is a glorious beacon of lightrrmccabe is a glorious beacon of lightrrmccabe is a glorious beacon of light
Take the intake off and dont put it back on until you get it tuned.
There is no reason to run an aftermarket intake without a tune. If you are away you are just asking for trouble with the dealer if your wife has to take it in.
