Jan-08-12, 08:08 PM
#1
Real Name: Tom
Member # 6069
fitment question
Will the 4L80E from a 94 Diesel swap into an 06 AWD?
Jan-08-12, 08:13 PM
#2
Dustin is my BITCH
Real Name: Jay
Member # 9298
no
Feb-16-12, 05:51 PM
#3
2007,AWD,3SS
Real Name: Eric
Member # 8723
Will a 4l80e from a 1997 1 ton work with my 07 AWD ? Found one and is $600 a good price?
PCM for Less:Tune,"Rob style Cam",.650 springs,160 stat,4'' FWI,plug wires& boots,3wire kit.LS7 MAF,Dorman E-fans,Pacesetter headers and no cat y-pipe,TR6 plugs.HIDextra 6k
Feb-16-12, 05:53 PM
#4
Dustin is my BITCH
Real Name: Jay
Member # 9298
I think it has to be an 01 newer for the electronics to work. Not a 100% on the year.
Feb-16-12, 07:43 PM
#5
DIY - King a destruction
Real Name: Walter
Member # 12143
Call a FLT and ask them what will work, they wont steer you wrong.
Feb-17-12, 08:51 AM
#6
Oil Rat, Oil & fuel parts
Real Name: Ross
Member # 61
NO!
Keep looking 1999+
.....TBSS 11.02@ 123mph 7000DA..............
Feb-17-12, 01:50 PM
#7
Plop
Real Name: Erik
Member # 9460
I have heard of some guys preferring older style cases - is this true, and why?
07 AWD, Forged 408,TVS2300, Aeromotive 340,Magnavolt,Meth T-mac & IW 8 rib, Comp s/c cam,LS1 E-fans,Kooks 1 7/8" LT, Dual 3", Magnaflow no cats,Rossler Terminator III 4L80E,Circle-D Stage III 258mm 3200,4" FWI 100mm MAF,Oil Rat pan,DJM Uppers and Swaybar,KW Coilovers,Spohn ctrl arms & Phb.
Feb-17-12, 03:54 PM
#8
Real Name: Ross
Member # 61
Not sure why! Greg and others have said the electronics would all need to be changed and the bell housing is missing the top bolt. If you really wanted too, you could use one! Just buy the right one if you can.
Feb-21-12, 05:10 AM
#9
Real Name: Aaron
Member # 4160
Status:
Online
I understand people are tryin to get a good deal on the older trans but its better to just go 99+ an run with it. But as its said on here its ur truck u do what u want. I would go with a 99+ tho lik I did.
 Addco F/R sway bars,kbees up front,springs/shocks out back, spals,160* t-stat,4" fenderwell CAI,Trans Cooler, LC32 Tuned,1 7/8 ARH LTs, 3'' true dual exhaust,4L80e,c6 pan,L92 heads...408ci next
Feb-21-12, 07:08 PM
#10
2007,AWD,3SS
Real Name: Eric
Member # 8723
Good info thanks
Jul-11-12, 12:33 PM
#11
Real Name: Mike
Member # 15957
Status:
Online
I'm not starting another thread so I will post here.
I've been looking Ito getting a 4l80 and have found 2000/01/02 with no problem at good prices. My problem is they all don't have the top bolt hole. Does this matter? I have turned down a couple because of this and am not sure if it even matters whether it has the mounting hole up top or not. Any help would be appreciated!
Originally Posted by ForceFed
I'll continue to stick by my motto.....
Don't Talk about it, Be about it.
Jul-11-12, 05:29 PM
#12
Real Name: Mike
Member # 15957
Status:
Online
Bump!
I noticed FLTs website shows them using the case w/out the upper hole.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
