Mar-02-12, 05:34 PM
#61
Real Name: Todd
Member # 4821
I highly doubt it would even run at 7.7.
Now offering screen printing services! PM me with any questions!
Mar-02-12, 06:01 PM
#62
Real Name: Erik
Member # 966
No kidding, probably choke itself out. Plus the plugs would show a super rich condition.
Matt, I havent had a single issue with my LC1 mounted right in front of my pass side NBO2 (stock manifolds) and use the serial output so I dont have to mess with ground offsets. Good point though, Jared check the ground offset and make sure the WB controller is calibrated correctly. If its reading 7.7, somethings off there.
08 3SS AWD, bolt-ons, suspension, 295/45R20 Hankook RH06, FR 20x10, SE22 Performance tuned, still mods in boxes
02 TB LT 4WD, 3" lift, ProComp/Bilstein HD shocks, Hotchkis rear, modded, tuned
Mar-03-12, 02:30 PM
#63
Real Name: Jared
Member # 9935
Originally Posted by jpracing01
Agreed, when I first installed my lc1.. Had all kinds of problems with it esp the analog output. It ended up being a grounding issue. My guess is you are seeing an offset issue in your grounding.
How do u have it grounded and where at?
Hook up the lc1 to your computer through serial port and see the readings.
Will do on Monday. At idle, it reads about 14.5, if that's any indicator of anything.
Mar-04-12, 01:36 PM
#64
Real Name: Nick
Member # 857
Which Wideband are you running? Sorry if you Said all ready...
06 TBSS AKA "TRUCK NORRIS"
VICTORY RACING ENGINES He's no longer waiting....
Mar-05-12, 10:29 AM
#65
Resident Porn Provider!
Real Name: Luis
Member # 1497
AFR's are fine.... It might be an offset on the wideband, but I've checked it with my portable one and we are on the money/a little on the rich side....
12.03 @ 115 MPH on Nitrous
Latest De-mod -BullNettles Magnacharged TBSS
Originally Posted by Meltdown211
He's the resident PORN barron.... C'mon, everyone knows this....
Mar-05-12, 11:40 AM
#66
Some PCM of NC bolton's
Real Name: William
Member # 74
Since you said it happened after headers take a look at the rear lift point on the driverside (on the block) when I installed my 1 7/8" I had to cut some of it off so it wouldnt hit the last primary. worth a shot. oh by the way you will have to feel for it, I think it's around 2-3 inches after the bend.
It's stock, just a couple bad plugs.
Mar-05-12, 01:06 PM
#67
Real Name: Luis
Member # 1497
Good info, i will check it out
Mar-08-12, 07:28 PM
#68
Real Name: Jared
Member # 9935
Mar-08-12, 07:33 PM
#69
Powered by Bath Salts
Real Name: Greg
Member # 1248
when i pop the wires on the coils, i takea 90* pick and slide it between the wire, and coil body... to escape the air from the socket.
do this. it will completely get rid of that problem.
Mar-08-12, 07:36 PM
#70
Real Name: Jared
Member # 9935
Will do, thank you! I take this place for granted at times. My pops taught me a lot, but mostly about tractors and lawn mowers (lived in BFE.)
Mar-23-12, 05:30 AM
#71
Real Name: Jared
Member # 9935
Wires are staying up, and it's back... New info. I resoldered one of the MAF wires (after unplugging it, to avoid heat damage) and the truck wouldn't start after I put everything back together. I unplugged the MAF to make sure that was the issue and sure enough, started right up. I plugged it back in, and the starter would just spin it. So then I fiddled around with the wires going into the harness and didn't find anything loose, but viola, truck has now been running for two days. ALSO, when I'm in 1st or 2nd, a full throttle push HAS NO KNOCK if there is no downshift. This lead me to believe that there is a wire losing contact somewhere in the engine bay upon the motor torquing over upon a sudden high rev from slow. Well, I took it to a private track and got it to 110 shifting manually so no downshifts and right around 110, while in 3rd, it came back. Any thoughts?
Also, if I'm still pushing boost and fuel into the motor and it pulls timing on spark from 17* to 7* IF IT IS SOMETHING BESIDES A LEGIT KNOCK IN THE MOTOR, wouldn't that cause a real knock at that point because the fuel and air will burn beyond the 0* mark on the stroke?
Reason: Added a theory
Mar-23-12, 12:57 PM
#72
Real Name: Jared
Member # 9935
AND now it's doing it in 2nd while the shifter is in second. On top of that, the damn thing was surging while driving normally. Did it about 3 times. It's never done that before. I'm gonna shoot it and get a fucking Civic.
Mar-23-12, 01:23 PM
#73
Real Name: JD
Member # 855
couple of ideas... just throwing them out there...
Re-wire everything related to the MAF
Get a new MAF, used MAF or burrow someone's working MAF (to rule that out as a possibility).
Reload tune
This sounds wiring/computer/tune related...
Mar-23-12, 01:27 PM
#74
Oil Rat, Oil & fuel parts
Real Name: Ross
Member # 61
It has to be something in your MAF wiring...
They will not heal on there own.
.....TBSS 11.02@ 123mph 7000DA..............
Mar-23-12, 01:32 PM
#75
Real Name: Jared
Member # 9935
Reload tune
Rewiring it this weekend if I can. New MAF is in there, did that about a month ago, didn't help at all. Will be reloading the tune this weekend, just to make sure.
LOL. Besides the resoldering of one wire, I didn't do anything but look to see where it went and pushed the harness back in a little. Yeah, sadly cars are not organic and don't just heal whatever, then have a cool scar.
Mar-24-12, 09:31 AM
#76
Real Name: Jared
Member # 9935
Truck died while rolling through a parking lot. Won't restart. Going to Luis's and I'm probably getting my daily driver today. Roadside assistance is paying for 120 of the cost of the tow. Fuel pump, crankshaft position sensor, hell, whatever it is, it's fuggin dead. Turns over, and over and over, nada.
Mar-24-12, 10:49 AM
#77
Hazing 4th
Real Name: Matt
Member # 64
Hope it turns out to be something small. DD is always a good idea when playing with hot rods.
08' C6 M6 743/647
93' Z28 A3- in pieces
06' RCSB H/C
Mar-24-12, 04:16 PM
#78
Real Name: Jared
Member # 9935
IT WAS THE GROUND WIRE OF THE MAF!!!!!!!!!!!!!!!!!!! Luis has the truck right now and we did multiple full boost passes and it's golden. I'm dumbfounded. Thank you everyone who helped get this POS ground wire found. I love this forum. D/D will be coming very soon. Then the cam and alky go in. I can finally stop stressing over this damn thing... If anyone is curious, if you lose your ground on the MAF, it cuts the spark and sends crazy data to your comp, making it "knock" when it's actually just pushing the gas out the exhaust and no firing is going on. I can't believe it was one damn wire.
Mar-25-12, 07:33 AM
#79
DIY - King a destruction
Real Name: Walter
Member # 12143
Glad you got it fixed! If your an 06, just get rid of the MAF, thats what I did, one less thing to go wrong, one less thing to tune and or give bad data.
Mar-25-12, 09:53 AM
#80
Hazing 4th
Real Name: Matt
Member # 64
I disagree. I would still run it hybrid for his setup.
08' C6 M6 743/647
06' RCSB H/C
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
