Go Back   TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum > TBSS Modifications > Power Adders > Superchargers and Turbos
Superchargers and Turbos From Maggies To Kenne Bell To STS
Old Mar-09-12, 09:00 AM   #21
griffincox
griffincox's Avatar
Real Name: Griffin
Member # 11614
Casino cash: $310900
Rep Power: griffincox is a jewel in the roughgriffincox is a jewel in the roughgriffincox is a jewel in the roughgriffincox is a jewel in the rough
Originally Posted by Rat Raceway View Post
Not sure on a 1900 my guess is around 7-8psi.
Anyone have any input on a 2.9" on tvs1900 at altitude? Is 7-8psi safe on a stock bottom end?
Old Mar-09-12, 09:16 AM   #22
Left Coast '32
MagnaCharger Sales
Left Coast '32's Avatar
Real Name: Joseph
Member # 19
Casino cash: $647300
Rep Power: Left Coast '32 has a brilliant futureLeft Coast '32 has a brilliant futureLeft Coast '32 has a brilliant futureLeft Coast '32 has a brilliant futureLeft Coast '32 has a brilliant futureLeft Coast '32 has a brilliant futureLeft Coast '32 has a brilliant futureLeft Coast '32 has a brilliant futureLeft Coast '32 has a brilliant futureLeft Coast '32 has a brilliant futureLeft Coast '32 has a brilliant future
We can set you up for 7-8 psi at that altitude no problem. I have several customers at altitude so we can get the boost dialed in no problem.
http://www.leftcoast32.com
07SSSC LSX390/AllPro LS3 "TVS2300" 18.5 psi
Authorized MagnaCharger Dealer/Distributor
Old Mar-13-12, 10:21 AM   #23
griffincox
griffincox's Avatar
Real Name: Griffin
Member # 11614
I have made a little progress on how I want to do things. Please critique as I know much less than most of you guys. I am basically going to do the build in two phases.*
Phase one:
- Modified AWD oil pan with remote filter
- rod bolts???
- LC32 cross member
- Stainless works long tubes
- plug wires
- NGK plugs
- RPM level 6 and yank sc2800
- full suspension front and rear
- alignment
- tuning
Phase two:
- TVS1900 with 2.9" rip pulley, ls2 car TB and hd tensioner
- intake???
- tuning*
I would like some feedback on whether or not to do rod bolts. The engine has 30k miles. *Not a lot of abuse. *Never been lacking oil to my knowledge. *ARP recommends rod work after install while katech *does not. I have never worked on a rotating assembly which makes me nervous. But I have a torque wrench and am very conscientious and like to do things right. I want the engine to last quite a while. Long enough to where I am not bitter when it breaks and I have to build a new one. I dont know how long that is haha. But at least a few years and many tens of thousands of miles.*
As for the intake. I know a fwi is ideal but I am still concerned with crap getting in it. Any compromise between full fwi and the stock maggie?
Anything else? *Thanks everyone!
Old Mar-13-12, 11:19 AM   #24
Rat Raceway
Oil Rat, Oil & fuel parts
Rat Raceway's Avatar
Real Name: Ross
Member # 61
Casino cash: $932566
Rep Power: Rat Raceway has a reputation beyond reputeRat Raceway has a reputation beyond reputeRat Raceway has a reputation beyond reputeRat Raceway has a reputation beyond reputeRat Raceway has a reputation beyond reputeRat Raceway has a reputation beyond reputeRat Raceway has a reputation beyond reputeRat Raceway has a reputation beyond reputeRat Raceway has a reputation beyond reputeRat Raceway has a reputation beyond reputeRat Raceway has a reputation beyond repute
Phase one:
- rod bolts???
- LC32 cross member
- plug wires
- NGK plugs
- alignment
- tuning
Phase two:
- intake???
- tuning*
IMO your headed down the right path!
I would hold off on the rod bolts! Just keep the money for when you forge your motor.
Mild boost with the other mods listed will get you low 13's up on the hill! YES, EVERYONE I SAID 13's!!!!!!!
You will stomp 90% of the street cars you find just cursing around town.
.....TBSS 11.02@ 123mph 7000DA..............
Old Mar-13-12, 07:11 PM   #25
griffincox
griffincox's Avatar
Real Name: Griffin
Member # 11614
Thanks Ross! Bump for some more input.
Old Mar-13-12, 10:52 PM   #26
gn2beatu
DIY - King a destruction
gn2beatu's Avatar
Real Name: Walter
Member # 12143
Casino cash: $498700
Rep Power: gn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond repute
Id go with the 3200 converter. You can skip the TB, its only 2mm bigger and wont make that big of a differance. Heck port your stock one. As for the intake, custom make an airbox with some aluminum, put the filter in the box (sealed from engine compartment air), then drill a 4" hole where you would put a FWI. Get some ducting from the 4" hole and run it to the foglamp, then you have a homemade ram-air 4" CAI that wont suck water in. Make sure to not block the three 1" holes in the fender, that way you can suck air through them if your truck ever ends up submerging the foglight area.
Old Mar-19-12, 05:02 AM   #27
dep
Real Name: Brian
Member # 12799
Casino cash: $101500
Rep Power: dep is on a distinguished road
I'd go with the 3200 converter too--I had a sc3000 and now my 4l80 stall is a loose 3000 and it comes out of the hole like animal. Wife daily drives it with no problem-- I would not be afriad of that intake--I take mine through car wash--etc-- that sock is from a jet ski!!! Low intake air temps are the key to timing and power!!! I'm gonna be doing a modded oil pan shortly(oil pressure dropping huge) and i'm not gonna do rod bolts.If its not broke--don't fucx with it.
LEP forged LS3-WCCH LS3 Heads-TVS 2300-T-Mac/I.W.10% overdriven-2.9 pulley-Kook's-3" duals-Phoenix 4l80-3200 stall-Circle D Billet Flex Plate-4" FWI intake-100% meth Alky Control-New 1/4 times coming this spring-10.??!Tuned by "Left Coast 32"
Old Apr-07-12, 10:57 PM   #28
JD_SS
JD_SS's Avatar
Real Name: JD
Member # 855
Casino cash: $587212
Rep Power: JD_SS is a splendid one to beholdJD_SS is a splendid one to beholdJD_SS is a splendid one to beholdJD_SS is a splendid one to beholdJD_SS is a splendid one to beholdJD_SS is a splendid one to beholdJD_SS is a splendid one to beholdJD_SS is a splendid one to behold
Well? Let's get moving Griffin!!
07 3ss awd | 402ci ls2 stroker
jake skull hitch covers
Old Apr-08-12, 09:09 AM   #29
griffincox
griffincox's Avatar
Real Name: Griffin
Member # 11614
Getting there. I basically just need to get the crossmember from Joe and get moving on the 1st phase. Here is some goodies to hold you over though.
Old Apr-08-12, 09:11 AM   #30
JD_SS
JD_SS's Avatar
Real Name: JD
Member # 855
Now we're talking! Did you go with stainless works?
Old Apr-08-12, 09:13 AM   #31
griffincox
griffincox's Avatar
Real Name: Griffin
Member # 11614
Indeed. Stainless Works with catted mid pipes into that borla muffler which has nice internal construction. Should sound great.
Old Apr-08-12, 09:17 AM   #32
Rat Raceway
Real Name: Ross
Member # 61
Very cool, coming along nicely.
Old Apr-08-12, 09:24 AM   #33
ForceFed
Love or Hate, Im still me
ForceFed's Avatar
Real Name: King Kyle
Member # 3919
Casino cash: $1477285
Rep Power: ForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond repute
YOur headers look different than mine at the collector. Mine are smooth where yours get smaller and them flare back up. What size is the outlet of the header, I am assuming 3''?
Old Apr-30-12, 07:46 AM   #34
griffincox
griffincox's Avatar
Real Name: Griffin
Member # 11614
Well. It has begun. I drained all the fluids last night. Everything looked clean coming out, so that's a good start. Going to just work slowly but surely to get everything off. Should have the pan off soon Ross, sorry for the delay. Any tips on where to start when removing the oil pan, transmission, converter, manifolds, cross member etc? *I will pull apart the front suspension and brakes first to take stress off.*
Kyle, I will take some measurements when I get the headers back from coating.*
Any tips are appreciated. All I am waiting on is A-arms and rear sway from Tony, and a panhard from LC32 after this next production run.*
Old Apr-30-12, 07:56 AM   #35
griffincox
griffincox's Avatar
Real Name: Griffin
Member # 11614
Sorry the pic is flipped. I'll fix it when im back to my comp.
Old Apr-30-12, 07:59 AM   #36
Rat Raceway
Real Name: Ross
Member # 61
Its Spider truck! I'm seeing your picture upside down!
On Jack stands I would say transfercase, then Trans.... DRAIN EVERYTHING YOU CAN!
Just let me know when your ready for the pan.
Old Apr-30-12, 08:06 AM   #37
JD_SS
JD_SS's Avatar
Real Name: JD
Member # 855
Congrats Giffin! Your picture is upside down though big daddy. Our necks will be killing us if you keep this up.
Don't forget heat socks for those wires!!
Old Apr-30-12, 08:51 AM   #38
griffincox
griffincox's Avatar
Real Name: Griffin
Member # 11614
It's right side up. The tires are just sticky.
I drained everything but the transmission. Should I drain that too? *
Transmission before anything up front or doesn't matter?
Originally Posted by JD_SS View Post
Congrats Giffin! *Your picture is upside down though big daddy. *Our necks will be killing us if you keep this up.
It's not my fault. It's Dropbox. I am going to start using something else. Pain in my ass.*
I don't think I'm going to put socks on though. From what I read with the nice PCM for less wires + 1 3/4" stainless works coated there should be no heat issues.*
Old Apr-30-12, 08:53 AM   #39
JD_SS
JD_SS's Avatar
Real Name: JD
Member # 855
Sounds good! You can always add socks later if you notice any melting! It was the 1 7/8" headers that NEED socks! Forgot about that!
Old Apr-30-12, 08:55 AM   #40
griffincox
griffincox's Avatar
Real Name: Griffin
Member # 11614
Thanks for looking out my man! I'll keep everyone updated.
