Go Back   TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum > TBSS Modifications > Power Adders > Superchargers and Turbos
Superchargers and Turbos From Maggies To Kenne Bell To STS
Closed Thread
Old May-02-12, 08:17 PM   #1061
Bad Monkey
Bad Monkey Racing
Bad Monkey's Avatar
Real Name: Damon
Member # 3977
Casino cash: $306190
Rep Power: Bad Monkey has a spectacular aura aboutBad Monkey has a spectacular aura aboutBad Monkey has a spectacular aura about
The ass of the VY C6 I had was always fuckin dirty, never again will I have a yellow vette lol. Sticking to silver.
If anything in your cooling system i.e. intercooler has aluminum in it, Meth and Aluminum do not play nice together, so if you planning on running a winterized washer fluid of some kind make sure it does not have meth in it, it will cause corrosion.
Sold
Old May-02-12, 08:31 PM   #1062
06WhiteSS
Resident Asshole!
06WhiteSS's Avatar
Real Name: Chad
Member # 642
Casino cash: $461267
Rep Power: 06WhiteSS has a reputation beyond repute06WhiteSS has a reputation beyond repute06WhiteSS has a reputation beyond repute06WhiteSS has a reputation beyond repute06WhiteSS has a reputation beyond repute06WhiteSS has a reputation beyond repute06WhiteSS has a reputation beyond repute06WhiteSS has a reputation beyond repute06WhiteSS has a reputation beyond repute06WhiteSS has a reputation beyond repute06WhiteSS has a reputation beyond repute
ETR2
2000 Camaro SS- Sold; 2006 TBSS LT AWD- K&N FIPK, DJM Upper A Arms, Belltech Lowering Struts, Slow, 30" on all four corners.....- Sold!!!
2007 Chevy Tahoe LTZ- All options except retractable running boards....
Old May-03-12, 02:13 PM   #1063
gn2beatu
DIY - King a destruction
gn2beatu's Avatar
Real Name: Walter
Member # 12143
Casino cash: $498700
Rep Power: gn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond repute
@ Damon - thanks for the tip. Is there an additive that could be put in with it to curb that? Im just goona run water for right now, but need a better solution before winter.
I wanna say the lowest water temp he has seen on a rainy day was VERY LOW 30's.....
Right now I have too many frickin electrical gremlins to fix before I redo my tune.... MAP is reading low, ETC TPS sensor acting goofy, etc. Then its tuning time, dyno time, and to get that famed 1/4 mile track time.
Already thinking of my phase two build thread - $800 more for a total of $3000, LS9 cam, springs, and head studs, then turn up the boost. That would be about $550, which leaves $250 left. That $250 is goona be for my homemade custom one off intake manifold that will flow 3600+ cfm @ 14psi. (4" flows 1800 cfm NA) Each cylinder will be fed with 2.5" which flows 521cfm each NA. Equal length runners with even airflow distribution should increase the airflow quite a bit, even at 14psi.
And if anyone is thinking I should hit goal one first, what makes you think I havent?
Cya @ the nats!!
Old May-03-12, 03:35 PM   #1064
endlink
endlink's Avatar
Real Name: Ed
Member # 6370
Casino cash: $324800
Rep Power: endlink will become famous soon enough
I'll start stockpiling aluminum cans for your intake manifold.
Sry couldn't resist.
Old May-03-12, 05:09 PM   #1065
ForceFed
Love or Hate, Im still me
ForceFed's Avatar
Real Name: King Kyle
Member # 3919
Casino cash: $1470885
Rep Power: ForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond repute
Cya @ the nats!!
I'd Say you Haven't there o' Mr. Benjamin Franklin or you would post it I'm sure.
Old May-03-12, 05:14 PM   #1066
gn2beatu
gn2beatu's Avatar
Real Name: Walter
Member # 12143
Maybe you should read my signature Kyle........... Why give you something to shoot for?
@ endlink - save em for someone else bud, mine is goona be made from the thinnest gauge steel mandrel bent tubing sections I can get from summit.
Old May-03-12, 05:20 PM   #1067
justanotherssuv
Do it once, do it right!
justanotherssuv's Avatar
Real Name: Brandon
Member # 9682
Casino cash: $594300
Rep Power: justanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond repute
DURAMAX_66
Walt, are these G-tech times?
07 White AWD 3SS.. Bolt ons.. Shift kit.. Stall.. Race tune by Ross Owens
AWD bolt on record holder 1.581 60' - 7.625 @ 87.77 - 12.114 @ 109.02mph
11's soon *fingers crossed*
Old May-03-12, 05:32 PM   #1068
Spivitz
the throttle is ur friend
Spivitz's Avatar
Real Name: Darren
Member # 13249
Casino cash: $322709
Rep Power: Spivitz has a brilliant futureSpivitz has a brilliant futureSpivitz has a brilliant futureSpivitz has a brilliant futureSpivitz has a brilliant futureSpivitz has a brilliant futureSpivitz has a brilliant futureSpivitz has a brilliant futureSpivitz has a brilliant futureSpivitz has a brilliant futureSpivitz has a brilliant future
Cmon now, at the drag strip....... 10.xx?
I think ur bluffing
2008 AWD Fast Motor Sports Cammed & Slammed…….
https://www.youtube.com/watch?v=TQqi-WsTQMA
Old May-03-12, 06:28 PM   #1069
Sleezy E
moar cowbell
Sleezy E's Avatar
Real Name: Eric
Member # 3039
Casino cash: $642000
Rep Power: Sleezy E has a reputation beyond reputeSleezy E has a reputation beyond reputeSleezy E has a reputation beyond reputeSleezy E has a reputation beyond reputeSleezy E has a reputation beyond reputeSleezy E has a reputation beyond reputeSleezy E has a reputation beyond reputeSleezy E has a reputation beyond reputeSleezy E has a reputation beyond reputeSleezy E has a reputation beyond reputeSleezy E has a reputation beyond repute
How did you get a qt mi run in when the truck goes into limp mode above 3k?
More bench racing I presume?
'06 5.3l turbo TB
'01 c5z
Old May-03-12, 06:51 PM   #1070
DoWork
DoWork's Avatar
Real Name: Todd
Member # 4821
Casino cash: $700463
Rep Power: DoWork is a splendid one to beholdDoWork is a splendid one to beholdDoWork is a splendid one to beholdDoWork is a splendid one to beholdDoWork is a splendid one to beholdDoWork is a splendid one to behold
LS2FTW
Wtf are "dyno times"?
Now offering screen printing services! PM me with any questions!
Old May-03-12, 06:53 PM   #1071
K5/SS
K5/SS's Avatar
Real Name: Dustin
Member # 7804
Casino cash: $1307400
Rep Power: K5/SS has a reputation beyond reputeK5/SS has a reputation beyond reputeK5/SS has a reputation beyond reputeK5/SS has a reputation beyond reputeK5/SS has a reputation beyond reputeK5/SS has a reputation beyond reputeK5/SS has a reputation beyond reputeK5/SS has a reputation beyond reputeK5/SS has a reputation beyond reputeK5/SS has a reputation beyond reputeK5/SS has a reputation beyond repute
"The bitterness of poor quality remains long after the sweetness of low pricing is forgotten"
Old May-03-12, 06:55 PM   #1072
justanotherssuv
Real Name: Brandon
Member # 9682
DURAMAX_66
Running a quarter mile on a dyno?
Old May-03-12, 06:58 PM   #1073
06WhiteSS
Resident Asshole!
06WhiteSS's Avatar
Real Name: Chad
Member # 642
ETR2
This thread gets more and more epic as time goes on....
Old May-03-12, 07:01 PM   #1074
lt1z
Hazing 4th
lt1z's Avatar
Real Name: Matt
Member # 64
Casino cash: $1517400
Rep Power: lt1z has a reputation beyond reputelt1z has a reputation beyond reputelt1z has a reputation beyond reputelt1z has a reputation beyond reputelt1z has a reputation beyond reputelt1z has a reputation beyond reputelt1z has a reputation beyond reputelt1z has a reputation beyond reputelt1z has a reputation beyond reputelt1z has a reputation beyond reputelt1z has a reputation beyond repute
Cya @ the nats!!
Was goal one making it home from FL?
08' C6 M6 743/647
93' Z28 A3- in pieces
06' RCSB H/C
Old May-03-12, 07:15 PM   #1075
gn2beatu
gn2beatu's Avatar
Real Name: Walter
Member # 12143
@ Sleezy - Limp mode happened days after the A/F was dialed in, limp mode happened on the way home.
@ Spivitz - Im not saying what my truck runs, til I get a 1/4 mile slip to prove it. I should have some dyno numbers in a week or so.
To the rest, it runs between 10.1 and 11.9 with the stock verter in it.
Im not posting a time, and here is why:
1. If its a g-tech number you wouldnt believe it anyways
2. It would give a certain someone a number to shoot for
3. What it runs now, it would be at LEAST .6 faster with the 3600, why guess, right?
4. Im goona do a post with a poll and a prize to see who guesses closest. Winner gets a ride at the nats, a choice of a burger lunch @ nats on me, or a couple beers afterward.
5. It will just plain be faster at the nats than what it is now anyways.... Boosts goin up baby!
Old May-03-12, 07:44 PM   #1076
ALL ULL C
ALL ULL C's Avatar
Real Name: Rich
Member # 1203
Casino cash: $228800
Rep Power: ALL ULL C has a spectacular aura aboutALL ULL C has a spectacular aura aboutALL ULL C has a spectacular aura about
This should help with your intake:
http://www.mandrel-bends.com/catalog...b3a77173f8a6a4
I would bet they will be cheaper than Summit and you can buy 2 sets for $150.
06' TBSS 2wd - Novi 2000
FMS tuned 688rwhp/579rwtq (13psi) Stock LS2+Cam
"Supra SS"
Old May-03-12, 08:17 PM   #1077
justanotherssuv
Real Name: Brandon
Member # 9682
DURAMAX_66
I really honestly can't wait for the actual track numbers. There's been some trial and error... There's been some sketchy installations at times... There are some cheap, possibly poorly made chinese parts being used... Of course we can't leave out the reused TTY rod bolts(unless Walter is actually smarter than he leads us on to be and actually bought and installed Katech or ARP rod bolts however he left them out of his 'budget' because they just simply are too expensive... He's over confident that the TTY bolts will not fail. I bet he changed them because OVERALL this build is realistically planned out pretty damn well). I would definitely say that if he gets this thing dialed in and everything works as Walter has planned, its going to be fast.
Old May-03-12, 08:44 PM   #1078
ForceFed
ForceFed's Avatar
Member # 3919
Walter, your not a street racer, so the only reason you have not to post, is its Fucking slow.
I ain't shooting for shit Walter, until you catch me, and have proof, you'll always be just one step behind. And remember, I wasn't even trying, and you're just giving it all you got.
King out.
(BTW, I am Posting this from a real 1/4 mile track...where my truck Ran tonight....How about you? )
Old May-03-12, 11:42 PM   #1079
gn2beatu
gn2beatu's Avatar
Real Name: Walter
Member # 12143
@Dowork - typo, should be dyno numbers ;-)
LOL @ the KING! Didnt know 13-14psi on a 40psi turbo was GIVING IT ALL IVE GOT!!!
Do they make a 1" pulley for you to do that? Or would you need a 18" crank pulley too?
Oh ya, thats right, you cant do that..... Isnt that called inefficiency? You paid how much?
I just hope the converter gets in before the nats is ALL I HAVE TO SAY!
Jaws will drop....
Old May-04-12, 03:02 AM   #1080
devus1
devus1's Avatar
Real Name: bubba
Member # 1713
Casino cash: $559680
Rep Power: devus1 has a brilliant futuredevus1 has a brilliant futuredevus1 has a brilliant futuredevus1 has a brilliant futuredevus1 has a brilliant futuredevus1 has a brilliant futuredevus1 has a brilliant futuredevus1 has a brilliant futuredevus1 has a brilliant futuredevus1 has a brilliant futuredevus1 has a brilliant future
There will not be a maggie truck run 10 anything at nats!!!! There only 2 of them deep enough into the 10s that june/july heat may not slow them down all the way out of the 10 second bracket.
1 of them isnt coming and the other ones getting a MANS blower installed.
If Walters truck can run anthing between 11.2-11.5 he got a shot to beat anybody there..
Closed Thread
