May-11-12, 02:01 PM
#1241
Powered by Bath Salts
Real Name: Greg
Member # 1248
care to expand on what you ran into with the aeromotive...
that is on my next round of "to do's" in a month or so.
May-11-12, 02:16 PM
#1242
Real Name: bubba
Member # 1713
Originally Posted by TBSSX
A nice single pump should be able to hang pretty well but depends on how high we are talking on boost level. Walbro 255 on 4 cyl at 30psi boost was fine. a 400 should be ok I would think for the 8.
I was referring to 20+ lbs
Greg check out Lonnies Fuel System...Alvin noticed a rash of Aeromotive pumps failing. We choose the RX double pump set up for mine..
May-11-12, 02:39 PM
#1243
Real Name: Jared
Member # 9935
Originally Posted by gn2beatu
@ Bullnettles - jeesh, Im only at like 90 days in the build and almost 4 weeks of that was in FL all the while not building anything....... Some builds last years! ;-)
Eh, it was a double entendre. Both we'll never see times because they'll never post, or you'll never run it, because you keep building. Either way, it's entertaining as hell to see how bent out of shape people get. I'm perplexed on a few parts, but I'm gonna kick my feet up and wait for the first video. Still on course to be at Nats?
May-11-12, 03:06 PM
#1244
Real Name: carl
Member # 4532
This was in a corvette that has twin tanks. Some people had issues with vapor locking. Mostly install error, or not using a PSC
if you use an eliminator pump, make sure to use the new smaller black Pump Speed controller. min volts 8.5 and full volts at max boost rpm or 4000, whichever comes first.
-Carl
May-11-12, 05:04 PM
#1245
Real Name: Tyler
Member # 16405
20+ psi will likely be safer to run a dual pump.
The mad scientist is in.
May-11-12, 05:08 PM
#1246
illegitiminoncarborundum
Real Name: Matt
Member # 64
20+ psi? Are we still talking about a stock LS2 bottom end with re used TTY bolts?
08' C6 M6 743/647
93' Z28 A3- in pieces
06' RCSB H/C
May-11-12, 05:35 PM
#1247
Real Name: Mark
Member # 534
Originally Posted by mbx5
Lords of light! Ariel, Oookla - RIDE! AwwwwHEEEE
^That was one of my favorites. Impressive reference.
 2007 White AWD Trailblazer 3SS, FMS Tune, ADM 4"CAI, PCMLS1 E-fans,Trans cooler,Wires,Yank SSTB 3600,FLT level V Trans, Kooks 1 7/8 catted Y,Corsa sport, Powder pro black stockers. & 2012 Cruze LTZ RS
May-11-12, 05:51 PM
#1248
Real Name: bubba
Member # 1713
You know me better than that...arp 234-4314 a step above there L 19
May-11-12, 06:10 PM
#1249
Real Name: Matt
Member # 64
Thats why I asked considering the thread this was in..
08' C6 M6 743/647
06' RCSB H/C
May-11-12, 07:48 PM
#1250
Member # 5696
i say fuck it and go for a 40 psi gtech run and let us know what 0-kabooom is.
May-11-12, 07:54 PM
#1251
Plop
Real Name: Erik
Member # 9460
07 AWD, Forged 408,TVS2300, Aeromotive 340,Magnavolt,Meth T-mac & IW 8 rib, Comp s/c cam,LS1 E-fans,Kooks 1 7/8" LT, Dual 3", Magnaflow no cats,Rossler Terminator III 4L80E,Circle-D Stage III 258mm 3200,4" FWI 100mm MAF,Oil Rat pan,DJM Uppers and Swaybar,KW Coilovers,Spohn ctrl arms & Phb.
May-12-12, 09:21 AM
#1252
DIY - King a destruction
Real Name: Walter
Member # 12143
Thats a great price on the 1518 for $188.00!! I was considering the Lunati springs for $128 as they have the same specs for pressure. But the .650 lift on the PAC is a big plus. Goona be doing the LS9 cam about 60-90 days from now, and that would leave room for higher ratio rockers down the road if I wanted to.
That eliminator pump is impressive for a single pump, 950lbs fuel @ 13.5v = 600lph. But the $473 the eliminator costs, just doesnt make sense to buy. For those that dont mind two pumps, it would make more sense to run twin 400 walbros and have more fuel. You can get the 400lph for $150 with the install kit. Most people dont know a single 400lph pump can support 800-850hp. I talked to Alvin about this before I bought mine, so thats why I ended up with what I did. Im @ 70% DC now with the 130lb/hr injectors, using the 400lph with the stock fuel lines & pressures, with no loss of fuel pressure.
Greg, twin 400lph at 13.5v at 4bar will flow ~ 700lph, that would save ya $173!! Im not a fan of running twin pumps though, so if the 400 or 450lph isnt enough, then I say go for the eliminator. Ive seen too many engines burn up cause one pump failed and they went lean.
Wonder if anyone makes a pressure switch a guy could run at the fuel rail tap, that you could use as an ignition cut if pressure fell off? It would just be a simple relay to hook up.
Fixed my plug wires, and still have popping. Its fine until the boost hits above 12psi and the wastegate opens. Going to do plugs in a little bit, hoping that fixes it. Just can seem to figure out why it does it when the wastegate opens. Boost is solid, no fluctuations, wastegates working fine, kinda stumped here. No reason why I can think of, other than springs, but it didnt do this before as its something recent.
May-12-12, 02:34 PM
#1253
Real Name: carl
Member # 4532
I dont think it would react fast enough to save a lean condition.
some guys use an LED to signal when the second pump comes on. No light, get off the gas. if primary pump ever dies, you could have quick disconnects and swap which pump runs all the time to make it home.
-Carl
May-12-12, 03:36 PM
#1254
Real Name: bubba
Member # 1713
there no way i would not run 2 pumps on e85 at 15 + lbs of boost...but what do I know. I still dont see how if this thing makes the power level hes saying it doesnt lift the head. I bought the best possible head stud they make without going to 1/2 inch...summit or jegs 2 of the biggest parts suppliers dont even stock them and I worried about lifting the head with a 4 bolt block..
May-13-12, 07:42 AM
#1255
Real Name: Petri
Member # 2962
Change your valve springs ASAP!! and shim them to .060" away from coil bind and your good to go, problems gone.
Pete
May-13-12, 05:43 PM
#1256
Canadian
Real Name: Ryan
Member # 5308
I have triple this budget in tattoos'
2006 Black AWD TBSS Jetttstream stage 3 CAI w/ AEM dry flow filter, Diablosport,160TStat,'07 wiper, vinyl overlays, servos, tranny cooler, Magnaflow 12259 w/ res. delete, 35% tint front, de-badged, billet bowtie, AMI 15'' antenna, LED reverse lights, Optima Red top w/ billet hold down, Nitto 420s, Hotchkis swaybar
May-13-12, 06:49 PM
#1257
Real Name: Walter
Member # 12143
Will the .650 PAC be enough spring to run 20psi down the road? Or do you have to shim em? Wasnt thinking I had to shim them for that. Your the first to mention shimming the aftermarket springs.
May-13-12, 09:39 PM
#1258
Real Name: Matt
Member # 64
I'd go with some nice duals with Ti retainers for that kind of boost. as well as upgrading the exhaust valve in those 243s. Of course if you don't build the bottom it will just destroy the heads when it comes apart so that may be throwing good money after bad. I would just stay at 14 psi and go with duals and see what it gets you.
I PM'd you a link to a good set of springs at a reasonable price.
08' C6 M6 743/647
06' RCSB H/C
May-14-12, 12:27 PM
#1259
Real Name: Petri
Member # 2962
By shimming them to correct height (depending your cam lift), will net you most seat pressure available from your springs. Also you should allways shim them to get most out of them(regarding performance and endurance), usually .050" away from bind.
Pete
May-15-12, 06:36 AM
#1260
Real Name: Walter
Member # 12143
Thanks Pete. When measuring for coil bind with feeler gauges at full lift, do you just measure one coil, or should there be .050 between every coil in the spring. Will be using the stock cam now, and the LS9 down the road. So no big lift. Shimming the 1518's should be plenty then, as they are 130lbs stock, and the springs Matt is talking about are 160. I could get to 160 with shims on the 1518's easy enough looking at the specs. Or am I missing something? The extra $100 isnt in my budget unfortunatly. Heck the extra $60 for the 1518's over the Lunati which have the same rate open are killing me. But I can see how the .650 lift could benefit me down the road. I already ordered the 1518's anyways, so the other ones Matt talked about arent an option anyways now.
After I put the new plugs in and ran it, on cold start up I could hear some lifter noise. Went under the engine to make sure it wasnt bottom end, and it wasnt. It went away almost completely after warm though, so I guess it could be piston slap. But it never had that before. Im thinking maybe when it popped it could have bent a pushrod or something too. Will be checking that when I throw the springs in. Compression is good on all cylinders at 190-196psi across the board. So that pretty much leaves valve noise, altho it wouldnt surprise me if its piston slap. Will know hopefully this weekend if its pushrod or piston, thats if the springs make it to me by Friday. I also pulled the injectors off one at a time while a neighbor loaded the engine. The noise is in the rear cylinder on drivers side. Pulling the injector makes the noise pretty much go away.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
