Mar-15-12, 06:58 PM
#1
Dyno Queen
Real Name: Jeremiah
Member # 5224
difference between aeromotive stealth and GSS341
Just wondering what the differences are between the 2 pumps? Everything I'm finding shows them identical.
I have the Lingenfelter TBSS pump now (GSS341), and will be going to an FI setup and simply looking for best single drop in pump.
Thanks!
Jeremiah
the fastest jackstands in the east!
Mar-15-12, 07:17 PM
#2
Oil Rat, Oil & fuel parts
Real Name: Ross
Member # 61
Status:
Online
Twins, IMO.
Always better to have more then you need.
They are pretty much the same as far as I see too.
.....TBSS 11.02@ 123mph 7000DA..............
Mar-15-12, 08:21 PM
#3
Dyno Queen
Real Name: Jeremiah
Member # 5224
Found a nice writeup for a cheap twin setup, may try that. I agree 2 is better, but im lazy too.
Mar-15-12, 08:29 PM
#4
DIY - King a destruction
Real Name: Walter
Member # 12143
As far as the best single, its the walbro 400, hands down. They have tested it against the 341, and the duetchworks, it beats both of them. Not sure if drop in is the right word, a little modifying may need to take place as it is larger, but still, if you want the best....
Mar-15-12, 08:49 PM
#5
illegitiminoncarborundum
Real Name: Matt
Member # 64
400 is not a direct drop in.
Bosch 044s are good too.
08' C6 M6 743/647
93' Z28 A3- in pieces
06' RCSB H/C
Mar-15-12, 09:34 PM
#6
Dyno Queen
Real Name: Jeremiah
Member # 5224
They are having lots of failures from what I'm reading. But once they work through that looks like it would work.
Thinking the twin pump might be the best idea, its just total fab work with the canister... or lack of canister I should say
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
