Jun-07-12, 02:42 PM
#201
Real Name: JD
Member # 855
Plastidip !
Jun-07-12, 06:11 PM
#202
Real Name: David
Member # 15633
man you are gonna love the 402. i had the number 6 rod go in mine back in january. Valve seals were leaking and burnt 2 qts of oil. shame on me for not checking it. Finally got the engine together two weeks ago. Tune time dyno tuned it at 411 hp and 403 torque.
Enjoy the new engine.
Jun-08-12, 05:59 AM
#203
Real Name: Jared
Member # 9935
Ready to see this thing alive, what's the ETA?
Jun-08-12, 08:44 AM
#204
Real Name: JD
Member # 855
ETA is month end. I have most of the parts ordered, but still have lots of little things left to order/pickup/pay for, including a new oil relocation hose-end fitting, new 160* tstat and fluids + misc
Other things still needed:
Stall from Griffin
Rat pan from Ross
Trans from shop
Dual cutouts
intake piping/LS7 MAF/filter
Muffler
Catch Can
I spent several hours last night cleaning engine parts in the solvent tank and removing old gasket remnents and seals. I cleaned hard lines, heads, differential, and misc parts.
The last couple hours included cleaning the block and starting assembly.
-mic'd the main and rod bearing journals, which were all within 1 thousandth of an inch to each other
-main bearings
-Crank
-Main caps / ARP studs
-file fit 2nd and top rings for #1 cylinder
-#1 piston assembly
-#1 rod bearings
-#1 cylinder complete
-block cleaned and wrapped
There was a corvette at the shop with 2,000 miles on a brand new motor. This guy paid a ton of money to have his vette built by a very well known company. Trent showed me how the cylinder walls were out of round and explained that this is why it's so important to have a reliable machine shop. This piston wobbles around in the cylinder when you push on it. You can see a lot of the top ring in these pics.
Jun-08-12, 08:51 AM
#205
The PinkBerry Beast :)
Real Name: Tab
Member # 1282
Awesome! Coming together very nicely JD
07 1SS 2WD, 11.57@117.19mph, 587hp/534tq, Pinkberry TVS1900, 3.0 pulley @ 8psi, WCCH LSA Heads, Custom Cam, LS2 car TB, PCMforLess 4” FWI, C6 Efan, 1¾ SW Headers, SW True Duals w/Turndowns, PCMforLess Trans Cooler, Built Trans, Yank SC3000, MPD Hood, Chrome FR 22s, TBM Blank Valance, Custom Pink Vinyl, etc.
Jun-08-12, 09:02 AM
#206
Real Name: Ryan
Member # 6700
Originally Posted by JD_SS
There was a corvette at the shop with 2,000 miles on a brand new motor. This guy paid a TON, and I mean, a TON of money to have his vette built by a very well known company.
So 2,000?
Hahah just playin, best of luck in the build. Cant wait to see it done
Jun-08-12, 09:26 AM
#207
Real Name: JD
Member # 855
Jun-08-12, 10:10 AM
#208
Dustin is my BITCH
Real Name: Jay
Member # 9298
Is that the damn ring?
Jun-08-12, 10:29 AM
#209
Real Name: JD
Member # 855
Yep.
Jun-08-12, 10:58 AM
#210
DIY - King a destruction
Real Name: Walter
Member # 12143
Time for a .020-.030 overbore or new sleeves Id say.
Jun-08-12, 11:04 AM
#211
GP Tuning
Real Name: Matt
Member # 64
Originally Posted by gn2beatu
Time new sleeves Id say.
fixed
08' C6 M6 743/647
06' RCSB H/C
Jun-08-12, 12:16 PM
#212
Real Name: JD
Member # 855
Time for a new block. I think the new sleeves would cost just as much as new block. Really unfortunate.
Jun-08-12, 08:20 PM
#213
Real Name: Walter
Member # 12143
Sleeves arent that bad. Blocks (new) are expensive big time, unless you can find a used one.
That almost looks like they bored the sleeves for bigger pistons, and put the stockers back in.
Jun-08-12, 08:38 PM
#214
Real Name: JD
Member # 855
I asked the same thing and he basically said that sleeving it would cost just about as much as a new block. Not exactly sure on the details. I think the customer wanted to start fresh with a new block and call it a day.
Jun-12-12, 07:17 AM
#215
Real Name: Brian
Member # 7652
I know that's what I would do, start fresh and make sure it's done right!
2007 AWD| Forged 402 | AFR heads | RPM level V | kooks 1 3/4 with ory/cats | 4" FWI | pcmforless transcooler | efans | circle D 3200 | R1 slotted rotors | SS braided brake lines |
Jun-12-12, 07:20 AM
#216
GP Tuning
Real Name: Matt
Member # 64
You think $1200-1500 is expensive for a brand new block?
08' C6 M6 743/647
06' RCSB H/C
Jun-12-12, 07:23 AM
#217
Some PCM of NC bolton's
Real Name: William
Member # 74
Blocks are not that bad, I had to choose between custom weisco pistons that were 6-8 weeks out or a new block same cost. I went with a new block.
It's stock, just a couple bad plugs.
Jun-13-12, 02:43 PM
#218
Real Name: JD
Member # 855
Jun-13-12, 02:49 PM
#219
Real Name: JD
Member # 855
Also, ring gaps for anyone interested..
Top .0053
2nd .0055
Jun-13-12, 02:49 PM
#220
the throttle is ur friend
Real Name: Darren
Member # 13249
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
