Go Back   TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum > Racing > Track Racing
Track Racing Safer Form of Racing
Old Apr-07-12, 08:42 PM   #21
lt1z
Hazing 4th
lt1z's Avatar
Real Name: Matt
Member # 64
Casino cash: $1517200
Rep Power: lt1z has a reputation beyond reputelt1z has a reputation beyond reputelt1z has a reputation beyond reputelt1z has a reputation beyond reputelt1z has a reputation beyond reputelt1z has a reputation beyond reputelt1z has a reputation beyond reputelt1z has a reputation beyond reputelt1z has a reputation beyond reputelt1z has a reputation beyond reputelt1z has a reputation beyond repute
Originally Posted by martyjw597 View Post
so, if it turns out being the front axle spline failure, should i just take it all out and convert to 2wd? Is there parts available to fix it or replace? And what needs to be done to the trans to go 2wd?
You will need a new trans output shaft and tail housing. You will also need front axle stubs from a RWD and a RWD driveshaft. Greg can get you the parts.
08' C6 M6 743/647
93' Z28 A3- in pieces
06' RCSB H/C
Old Apr-07-12, 08:57 PM   #22
martyjw597
Needs more$
martyjw597's Avatar
Real Name: marty
Member # 8397
Casino cash: $679900
Rep Power: martyjw597 has a reputation beyond reputemartyjw597 has a reputation beyond reputemartyjw597 has a reputation beyond reputemartyjw597 has a reputation beyond reputemartyjw597 has a reputation beyond reputemartyjw597 has a reputation beyond reputemartyjw597 has a reputation beyond reputemartyjw597 has a reputation beyond reputemartyjw597 has a reputation beyond reputemartyjw597 has a reputation beyond reputemartyjw597 has a reputation beyond repute
Just wondering which way is cheaper and easier...guess i gotta see whats wrong first.
06 2wd conversion, LT1Z HCI, 12.03 AWD cam only rec. holder. 11.91 2wd cam only, 11.72 w/room for improvement HCI
Old Apr-07-12, 09:12 PM   #23
lt1z
Hazing 4th
lt1z's Avatar
Real Name: Matt
Member # 64
If it's the trans it would be cheapest and easiest to to rebuild it and stay AWD. If the diff is broken it may be easier to just go RWD.
08' C6 M6 743/647
06' RCSB H/C
Old Apr-07-12, 10:37 PM   #24
unfnny1
unfnny1's Avatar
Real Name: Mike
Member # 2355
Casino cash: $589500
Rep Power: unfnny1 has much to be proud ofunfnny1 has much to be proud ofunfnny1 has much to be proud ofunfnny1 has much to be proud ofunfnny1 has much to be proud ofunfnny1 has much to be proud ofunfnny1 has much to be proud ofunfnny1 has much to be proud ofunfnny1 has much to be proud ofunfnny1 has much to be proud of
SMRTSS1
When I had the spline failure my truck wouldn't move more than a few feet and sounded like something was loose in the trans linkage when I tried going thru all the gears. I felt/heard a boom then I was dead in the water. When my trans went I still had reverse and 1st and 2nd. Either way a 2wd conversion would be best and I wish I did that when I had the chance and more money than I do now. Replacing my blown trans with another stock unit was $2300, spline failure was $3600. If its the splines you'd be better off making it 2wd and never having to worry about it again, trust me it's no fun waiting for it to happen again and from the mileage intervals when it seems to happen I'm about due for it again. Good luck, I hope it works out for you.
It saddens me that what I do for a living allows idiots to be on the internet
Old Apr-07-12, 10:43 PM   #25
JD_SS
JD_SS's Avatar
Real Name: JD
Member # 855
Casino cash: $581412
Rep Power: JD_SS is a splendid one to beholdJD_SS is a splendid one to beholdJD_SS is a splendid one to beholdJD_SS is a splendid one to beholdJD_SS is a splendid one to beholdJD_SS is a splendid one to beholdJD_SS is a splendid one to beholdJD_SS is a splendid one to behold
Originally Posted by lt1z View Post
It works in three ways.
1. The shorter diameter maximizes the trucks gearing with 4.10s to go through the traps near redline in 3rd
2. A stickier tire will 60 ft better
3. The shorter DR setup on 17s saves a good amount or rotating weight over stock 20s which leads to quicker acceleration.
Originally Posted by mitch kramer baby! View Post
I know your very intelligent person so I dont know if you were joking or not.
but, best reson is weight, tire options, and yes depending on gear ratio and shit, people change them up so lets say they dont have to do the last shift kind of thing
No, not joking at all! I've seen a lot of guys up here on the hill running with the stock 20's in the past, Spddman to mention one name, and he ran 11.5's! Aside from Ross, who is NOW 2WD, I don't think I've seen an AWD on smaller wheels and DR's on all 4 corners. I didn't think traction would really be an issue on an AWD truck until you get into HUGE HP numbers, at which point I see guys convert to 2wd. Pardon the ignorance on my part Thanks for explaining!! Would DR's be good on crappy old steelies?
Sorry, back to OP/Topic!!
07 3ss awd | 402ci ls2 stroker
jake skull hitch covers
Old Apr-07-12, 10:49 PM   #26
WongBob
High and Tight!!!
WongBob's Avatar
Real Name: Wade
Member # 5354
Casino cash: $426650
Rep Power: WongBob has much to be proud ofWongBob has much to be proud ofWongBob has much to be proud ofWongBob has much to be proud ofWongBob has much to be proud ofWongBob has much to be proud ofWongBob has much to be proud ofWongBob has much to be proud ofWongBob has much to be proud ofWongBob has much to be proud of
Radials would be great on steelies. It will mostly help you with gearing on a low horsepower setup. When you start making a lot of power then it is for traction. When you are looking for ET and you already have traction... thats when you call Bogart, CCW, or True Forged and get some lightweight wheels.
Cam Only Record Holder 1.467 60', 11.568 @ 116.86
http://www.tbssowners.com/forums/image.php?type=sigpic&userid=5354&dateline=1320607  794
Old Apr-07-12, 11:05 PM   #27
lt1z
Hazing 4th
lt1z's Avatar
Real Name: Matt
Member # 64
The 245/45/17 size is perfect for the steel spares on an AWD. There are a lot of EVOs in the 9's running that tire setup. You haven't seen many AWD DR setups because most people didn't want to buy 4 wheels and tires.
08' C6 M6 743/647
06' RCSB H/C
Old Apr-08-12, 06:15 AM   #28
twmSS
twmSS's Avatar
Real Name: Tom
Member # 15798
Casino cash: $309500
Rep Power: twmSS is a splendid one to beholdtwmSS is a splendid one to beholdtwmSS is a splendid one to beholdtwmSS is a splendid one to beholdtwmSS is a splendid one to beholdtwmSS is a splendid one to beholdtwmSS is a splendid one to behold
Congrats man
Old Apr-08-12, 06:24 AM   #29
martyjw597
Needs more$
martyjw597's Avatar
Real Name: marty
Member # 8397
Why was the spline failure $3600? Was that for parts and labor? How much are just the parts?
Old Apr-08-12, 06:34 AM   #30
martyjw597
Needs more$
martyjw597's Avatar
Real Name: marty
Member # 8397
Originally Posted by twmSS View Post
Congrats man
Thanks...kinda bitter sweet with breaking something on the way home
Old Apr-08-12, 06:44 AM   #31
ForceFed
Love or Hate, Im still me
ForceFed's Avatar
Real Name: King Kyle
Member # 3919
Casino cash: $1470885
Rep Power: ForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond repute
WTH are front Axle Stubs?
And congrats on the time Marty.
Old Apr-08-12, 06:57 AM   #32
martyjw597
Needs more$
martyjw597's Avatar
Real Name: marty
Member # 8397
Thanks
Old Apr-08-12, 07:06 AM   #33
WongBob
High and Tight!!!
WongBob's Avatar
Real Name: Wade
Member # 5354
I think someone is due for a sig update.
Old Apr-08-12, 08:02 AM   #34
unfnny1
unfnny1's Avatar
Real Name: Mike
Member # 2355
SMRTSS1
As always labor was the killer. I was accelerating onto the highway when mine went and it not only took the splines off the shaft it killed the bearings and the entire housing. Plus they went past the point of damage and re-did everything to the differential and checked the diff for damage as well. The way they rebuilt it was above and beyond the normal (hence the price) and I shouldn't have to worry about it again but I still do.
Old Apr-08-12, 08:11 AM   #35
martyjw597
Needs more$
martyjw597's Avatar
Real Name: marty
Member # 8397
Thats sounds like what happened to me. Was accelerating on 294 and no more movement. If that is the problem...2wd here i come
Old Apr-08-12, 08:23 AM   #36
ssdrooler
Real Name: Colin
Member # 8349
Casino cash: $129100
Rep Power: ssdrooler will become famous soon enough
Marty good to meet you yesterday. Bittersweet indeed. Let me know if you need a hand wrenching if you are gonna tackle the fix yourself. God knows im pushing my luck as well.
2007 AWD: V1 HOB Kit with F1 Procharger, Kooks 1 7/8" w/ catted Y, Corsa Touring, 160stat, efans, Tranny Coola, Shift Kit, Sonnax Servos, Yank SSTB3200, Kbees, DJM Uppers, R1 d/s Rotors, DJM Rear Sway. 262 Tune.
Old Apr-08-12, 08:25 AM   #37
Northeast TBSS
Northeast TBSS's Avatar
Real Name: Todd
Member # 8275
Casino cash: $229000
Rep Power: Northeast TBSS is just really niceNortheast TBSS is just really niceNortheast TBSS is just really niceNortheast TBSS is just really nice
Congrats on times nice runs. Sorry about the failure on the way home good luck with repairs
2006 AWD 4L80E LEP 365 TVS 1900 T-Mac LeftCoast32 12.03@113 60'1.72
2008 Ducati 848 Pearl White 10.9@128clfs Sold
2012 Aprilia Tuono V4R times to come
Old Apr-08-12, 09:12 AM   #38
martyjw597
Needs more$
martyjw597's Avatar
Real Name: marty
Member # 8397
Good to meet you to. Your truck runs good too.
Thanks!
Old Apr-08-12, 09:32 AM   #39
not quick
Dustin is my BITCH
not quick's Avatar
Real Name: Jay
Member # 9298
Casino cash: $940824
Rep Power: not quick has a reputation beyond reputenot quick has a reputation beyond reputenot quick has a reputation beyond reputenot quick has a reputation beyond reputenot quick has a reputation beyond reputenot quick has a reputation beyond reputenot quick has a reputation beyond reputenot quick has a reputation beyond reputenot quick has a reputation beyond reputenot quick has a reputation beyond reputenot quick has a reputation beyond repute
Good numbers, congratts
Goes in the hub. I guess it holds it together never had mine off
Old Apr-08-12, 09:47 AM   #40
justanotherssuv
Do it once, do it right!
justanotherssuv's Avatar
Real Name: Brandon
Member # 9682
Casino cash: $594300
Rep Power: justanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond repute
DURAMAX_66
Good times Marty!!!
Just a thought, stay AWD and 11's are yours later this year....
Convert to 2wd, no 11 second AWD slip for you...
Either way, you still have a damn fast truck!!!!
07 White AWD 3SS.. Bolt ons.. Shift kit.. Stall.. Race tune by Ross Owens
AWD bolt on record holder 1.581 60' - 7.625 @ 87.77 - 12.114 @ 109.02mph
11's soon *fingers crossed*
