Go Back   TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum > TBSS Modifications > Power Adders > Superchargers and Turbos
Superchargers and Turbos From Maggies To Kenne Bell To STS
Old Apr-10-12, 04:36 PM   #1
darkhorizon
Real Name: Scott
Member # 12380
Casino cash: $66300
Rep Power: darkhorizon has a spectacular aura aboutdarkhorizon has a spectacular aura about
Default Slightly less fail sub $1000 turbo build...
While I have built many cars, and never posted a build thread before they were well underway... I decided I would make a small exception here as I have only put together a few boosted LS cars, and none were LS2s, so I have a few questions while I gather the rest of my parts.
Anyway, plan is put a 60mm VGT turbo under the passenger seat, STS style I guess, toss some valve springs on the valves, toss a deatchwerks 300LPH fuel pump in the tank, and run E85 on some 50# injectors. Should be good for a 70whp gains and some extra power under 4000rpms. I had this turbo on a LS1 camaro for awhile and it was an absolute monster down low. The exhaust side will leave some to be desired but I am not looking to set power records here.
Trans is built with a stock converter. Tuning will be done via HPT if I ever get a new pair of PCM/TCMs for it as mine are currently locked out.
Scavenge pump is decided, I just dont know if I should get the "exa" brand or the base model?
http://turbowerx.com/Scavenge_Pumps/...odel_Pump.html
As far as valvesprings go on a stock cam, I was planning on some comp blue stripes, but if someone else has a better suggestion let me know.
Currently planning on no intercooler... Going to run a LT1 maf and hope for the best on not maxing it out. I dont expect to run into issues with the 1bar map right?
Any other little mods I should make? I am just doing this for gains similar to a cam, without the side effects. I run E85 in all of my other race car stuff so that just comes with my style I suppose. Its going to be used for 95% tow duty as well, my sub 10 second rides dont drive themselves to the track much anymore.
Old Apr-10-12, 04:44 PM   #2
not quick
Dustin is my BITCH
not quick's Avatar
Real Name: Jay
Member # 9298
Casino cash: $947624
Rep Power: not quick has a reputation beyond reputenot quick has a reputation beyond reputenot quick has a reputation beyond reputenot quick has a reputation beyond reputenot quick has a reputation beyond reputenot quick has a reputation beyond reputenot quick has a reputation beyond reputenot quick has a reputation beyond reputenot quick has a reputation beyond reputenot quick has a reputation beyond reputenot quick has a reputation beyond repute
How do you control the vanes?
Old Apr-10-12, 04:47 PM   #3
ForceFed
Love or Hate, Im still me
ForceFed's Avatar
Real Name: King Kyle
Member # 3919
Casino cash: $1479185
Rep Power: ForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond reputeForceFed has a reputation beyond repute
Interested in seeing this.
Good luck.... And less fail shouldn't be too hard since you're not shooting for the moon with a BB Gun.
Old Apr-10-12, 04:49 PM   #4
darkhorizon
Real Name: Scott
Member # 12380
Casino cash: $66300
On MOST of the VGT mods I have setup I just use a DSM wastegate actuator that pops the VGT open under boost, and holds it about 30-50% open, then the actuator pushes it open around 8psi.
The function of it will not be particularly as good this go around as I will not be making enough boost pressure to make most any actuator work the way I want, so I plan on just putting a spring on, and adjusting the tension of it, as well as the starting point (it will probably remain half open or even more at "idle".) The boost pushes on the vanes hard so it works pretty decent.
Old Apr-10-12, 04:51 PM   #5
darkhorizon
Real Name: Scott
Member # 12380
Casino cash: $66300
I hope that things go smoothly, as I have installed a good handful of boosted LSx stuff, and personally own 3 turbo cars I built myself (honda crx, and 2 turbo fieros).
Old Apr-10-12, 05:44 PM   #6
Bullnettles
Bullnettles's Avatar
Real Name: Jared
Member # 9935
Casino cash: $678460
Rep Power: Bullnettles has a reputation beyond reputeBullnettles has a reputation beyond reputeBullnettles has a reputation beyond reputeBullnettles has a reputation beyond reputeBullnettles has a reputation beyond reputeBullnettles has a reputation beyond reputeBullnettles has a reputation beyond reputeBullnettles has a reputation beyond reputeBullnettles has a reputation beyond reputeBullnettles has a reputation beyond reputeBullnettles has a reputation beyond repute
Subscribed, can't wait to see how it turns out. Good luck.
Old Apr-10-12, 05:46 PM   #7
not quick
Dustin is my BITCH
not quick's Avatar
Real Name: Jay
Member # 9298
Can you show more on the waste gate on the vg part of it. I thought they had an electric motor/servo on them.
Old Apr-10-12, 06:32 PM   #8
ti28
SMFH
ti28's Avatar
Real Name: Tim
Member # 2694
Casino cash: $1299586
Rep Power: ti28 has a reputation beyond reputeti28 has a reputation beyond reputeti28 has a reputation beyond reputeti28 has a reputation beyond reputeti28 has a reputation beyond reputeti28 has a reputation beyond reputeti28 has a reputation beyond reputeti28 has a reputation beyond reputeti28 has a reputation beyond reputeti28 has a reputation beyond reputeti28 has a reputation beyond repute
That big silver block with the wire is the servo.......
Old Apr-10-12, 06:48 PM   #9
not quick
Dustin is my BITCH
not quick's Avatar
Real Name: Jay
Member # 9298
I under stand that but, I was curious on how the waste gate hooked up to the disk that controls the vanes.
Old Apr-10-12, 07:05 PM   #10
ForceFed
ForceFed's Avatar
Member # 3919
If its like a diesel variable vane turbo, there is no wastgate, the vanes control all
The boost.
Old Apr-10-12, 07:10 PM   #11
justanotherssuv
Do it once, do it right!
justanotherssuv's Avatar
Real Name: Brandon
Member # 9682
Casino cash: $595900
Rep Power: justanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond reputejustanotherssuv has a reputation beyond repute
DURAMAX_66
It looks like its off a 07.5-08 Cummins...
07 White AWD 3SS.. Bolt ons.. Shift kit.. Stall.. Race tune by Ross Owens
AWD bolt on record holder 1.581 60' - 7.625 @ 87.77 - 12.114 @ 109.02mph
11's soon *fingers crossed*
Old Apr-10-12, 07:11 PM   #12
not quick
Dustin is my BITCH
not quick's Avatar
Real Name: Jay
Member # 9298
The boost.
Yes But he is using a wg to control the vanes of it. I'm thinking like a internal style wg actuator
Old Apr-10-12, 07:28 PM   #13
ForceFed
ForceFed's Avatar
Member # 3919
The vanes are on a ring that spins. Have you ever seen how they are setup? If not, there's a nice YouTube demonstration on how one works. Search it.
Old Apr-10-12, 07:30 PM   #14
jake 03
jake 03's Avatar
Real Name: Jacob
Member # 3489
Casino cash: $272300
Rep Power: jake 03 is a splendid one to beholdjake 03 is a splendid one to beholdjake 03 is a splendid one to beholdjake 03 is a splendid one to beholdjake 03 is a splendid one to beholdjake 03 is a splendid one to beholdjake 03 is a splendid one to behold
Forged 365,Tvs1900@11 psi,IW overdrive 8 rib,LC32 duel pass,meth,custom cam,PRC heads,Yank,areomotive,some more goodies..
Old Apr-10-12, 07:33 PM   #15
not quick
Dustin is my BITCH
not quick's Avatar
Real Name: Jay
Member # 9298
Yeah, I rebuild one on a 6.0 for a guy at work. I just want to see how this custom set up works. It seems pretty Interesting.
Old Apr-10-12, 07:46 PM   #16
JD_SS
JD_SS's Avatar
Real Name: JD
Member # 855
Casino cash: $588112
Rep Power: JD_SS is a splendid one to beholdJD_SS is a splendid one to beholdJD_SS is a splendid one to beholdJD_SS is a splendid one to beholdJD_SS is a splendid one to beholdJD_SS is a splendid one to beholdJD_SS is a splendid one to beholdJD_SS is a splendid one to behold
Exa pump!!! do not settle on scav pump! And you really should get a pressure switch with alarm otherwise if your pump fails you may not realize you are losing oil pressure, pushing your turbo seals and potentially injesting oil via throttle body! Stainless steal lines. Also need to get a catch can with check vales like the rx can. Fuel pump is not necessary and 42lb ford racing green top injectors would be perfect. Header wrap will help a ton with spool.
07 3ss awd | 402ci ls2 stroker
jake skull hitch covers
Old Apr-10-12, 08:34 PM   #17
darkhorizon
Real Name: Scott
Member # 12380
Casino cash: $66300
here is how I did it in the last one.
It does not control boost at all... Even slamming it open from almost closed will not decrease the intake boost pressure at all... It may slow it down some but it will still make 20psi+ without a wastegate. The VGT part is basically a hamburger that crunches around the exhaust wheel to increase or decrease the velocity of exhaust hitting it.
I will start off using a light spring and a stopper at about 50% open... The TIP should push it all the way open, then I can just hope the spring brings it back.
Not going to cut it for E85 though. I have a good idea what I need here I believe.
Pics look great, thanks for posting them.... Any reason you couldnt push it up closer to the trans mount bar? I was hoping to nearly have it coming right off the factory Y pipe. I have already deleted my cats, so I am hoping to gain huge in spool off that mod... although I am not too worried about it with the VGT.
Where did you run the oil return from the exa to? I did it to the oil cap in the last STS I setup... Worked OK I suppose but I would like to put it back in the oil pan....
Old Apr-10-12, 08:52 PM   #18
ScarabEpic22
ScarabEpic22's Avatar
Real Name: Erik
Member # 966
Casino cash: $331040
Rep Power: ScarabEpic22 is a name known to allScarabEpic22 is a name known to allScarabEpic22 is a name known to allScarabEpic22 is a name known to allScarabEpic22 is a name known to allScarabEpic22 is a name known to all
You're gonna need a 2Bar MAP at least, dont bother with a 1Bar MAP.
Looks like a cool setup to me, I like the idea behind VGTs a lot!
What year truck is yours, Ive got an extra set of E67/T42 computers I might be willing to part with. They have the 08 stock OS currently.
08 3SS AWD, bolt-ons, suspension, 295/45R20 Hankook RH06, FR 20x10, SE22 Performance tuned, still mods in boxes
02 TB LT 4WD, 3" lift, ProComp/Bilstein HD shocks, Hotchkis rear, modded, tuned
Old Apr-10-12, 08:56 PM   #19
darkhorizon
Real Name: Scott
Member # 12380
Casino cash: $66300
Why would I need a 2bar? I would rather just delete the MAP sensor if I have to deal with bodging on a 2bar (although I have a box full of 10+ 2bar sensors).
I am not too sure the compatability between the 07 and the 08 pcms? I know that a 06 will not work but would an 08 go into a 07/.
Old Apr-10-12, 10:30 PM   #20
XMONTE
Member # 1249
Casino cash: $188300
Rep Power: XMONTE is just really niceXMONTE is just really niceXMONTE is just really niceXMONTE is just really niceXMONTE is just really nice
That's exactly wat I was thinking..
it looks like a holset turbo, if it is were having alotta problems wit them on the Orion hybrid buses.. the variable vain sys is jamming and not letting the turbo spool up..
