Go Back   TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum > TBSS Drivetrain > 4L70E Transmission Help
4L70E Transmission Help Tranny Info and Upgrades including torque converters (stall)
Old Apr-23-12, 08:32 AM   #1
Dimm6
Real Name: Jimmy
Member # 16473
Casino cash: $78300
Rep Power: Dimm6 is an unknown quantity at this point
Default Won't shift into 1st
As the title states, my new to me 2007 TBSS AWD won't shift into first gear when I up the lever to 1. Its a little hard to get the lever to go down there. It almost feels like the shift boot bunches up and won't let it go. But once I get it there, the car won't take off in 1st.
Any thoughts?
Old Apr-23-12, 11:17 AM   #2
gn2beatu
DIY - King a destruction
gn2beatu's Avatar
Real Name: Walter
Member # 12143
Casino cash: $498700
Rep Power: gn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond reputegn2beatu has a reputation beyond repute
Check to see if the cable is stretched or needs adjusting. Put it up in the air on a lift, and check if you manually move the lever on the tranny a bit more if it will go in. Adjust/fix/replace as needed.
Old Apr-23-12, 11:48 AM   #3
Nightmare
CAMMED AND SLAMMED
Nightmare's Avatar
Real Name: Clint
Member # 81
Casino cash: $278706
Rep Power: Nightmare has much to be proud ofNightmare has much to be proud ofNightmare has much to be proud ofNightmare has much to be proud ofNightmare has much to be proud ofNightmare has much to be proud ofNightmare has much to be proud ofNightmare has much to be proud of
Mine gets tighter the further you pull it toward 1st..but it will always go in the gear.
I know I didnt answer your question but I wanted you to know mine gets tight too(no pun intended)
Old Apr-23-12, 01:32 PM   #4
Dimm6
Real Name: Jimmy
Member # 16473
Casino cash: $78300
Thanks for the tips. My mom's old Benz from the eighties used to start in second gear and only use first when mashing the throttle. I think it was because there may have been too much torque for the tranny to handle in first. I thought maybe this was the case as well, but I guess not. Ill check the cable out when I get it up on a lift.
Old Apr-23-12, 01:34 PM   #5
Bullnettles
Bullnettles's Avatar
Real Name: Jared
Member # 9935
Casino cash: $678360
Rep Power: Bullnettles has a reputation beyond reputeBullnettles has a reputation beyond reputeBullnettles has a reputation beyond reputeBullnettles has a reputation beyond reputeBullnettles has a reputation beyond reputeBullnettles has a reputation beyond reputeBullnettles has a reputation beyond reputeBullnettles has a reputation beyond reputeBullnettles has a reputation beyond reputeBullnettles has a reputation beyond reputeBullnettles has a reputation beyond repute
Does it actually go into 1st when you start in 3 or D?
Old Apr-23-12, 03:00 PM   #6
Dimm6
Real Name: Jimmy
Member # 16473
Casino cash: $78300
It starts in 1st, but when I put the lever into 1 it starts from 2nd and if I stomp on the gas hard enough it downshifts into 1st.
Should it always start in first when in D? Or does it start off in second? I've only had the car for about a week, so I'm not sure what it should be doing.
Old Apr-23-12, 03:26 PM   #7
martyjw597
Needs more$
martyjw597's Avatar
Real Name: marty
Member # 8397
Casino cash: $680300
Rep Power: martyjw597 has a reputation beyond reputemartyjw597 has a reputation beyond reputemartyjw597 has a reputation beyond reputemartyjw597 has a reputation beyond reputemartyjw597 has a reputation beyond reputemartyjw597 has a reputation beyond reputemartyjw597 has a reputation beyond reputemartyjw597 has a reputation beyond reputemartyjw597 has a reputation beyond reputemartyjw597 has a reputation beyond reputemartyjw597 has a reputation beyond repute
Should start in first
06 2wd conversion, LT1Z HCI, 12.03 AWD cam only rec. holder. 11.91 2wd cam only, 11.72 w/room for improvement HCI
Old Apr-23-12, 05:35 PM   #8
Dimm6
Real Name: Jimmy
Member # 16473
Casino cash: $78300
Ok I got it figured out. Now it works fine. I'm a tool. Lol.
Old Apr-23-12, 05:39 PM   #9
Bullnettles
Real Name: Jared
Member # 9935
Old Apr-23-12, 05:45 PM   #10
martyjw597
Needs more$
martyjw597's Avatar
Real Name: marty
Member # 8397
Old Apr-09-13, 11:00 AM   #11
botlfed98
Real Name: DICK HEAD
Member # 1571
Casino cash: $53700
Rep Power: botlfed98 is on a distinguished road
what was the issue?
Old Apr-09-13, 04:59 PM   #12
1FAST07SS
1FAST07SS's Avatar
Real Name: Brian
Member # 7652
Casino cash: $473400
Rep Power: 1FAST07SS is a jewel in the rough1FAST07SS is a jewel in the rough1FAST07SS is a jewel in the rough
Common you gotta tell us what it was!!!!!!!!! Or was it a lol
2007 AWD| Forged 402 | AFR heads | RPM level V | kooks 1 3/4 with ory/cats | ieatsrt8 intake | pcmforless transcooler | efans | circle D 3200 | R1 slotted rotors | SS braided brake lines |
