May-07-12, 08:11 AM
#1
Real Name: Caleb
Member # 12890
Status:
Online
100% Meth Injection Vs. Water/Meth Mixture
What are the pros and cons of each? Looking into a Meth setup, trying to decide which to go with.
Built motor, trans, stall. Procharger (D-1SC) setup.
Who has what and why did you go with it?
May-07-12, 08:35 AM
#2
Hazing 4th
Real Name: Matt
Member # 64
Status:
Online
100% is the only way to go.
08' C6 M6 743/647
93' Z28 A3- in pieces
06' RCSB H/C
May-07-12, 09:02 AM
#3
Real Name: Dave
Member # 18
Status:
Online
You'll get much better cooling with 100%.
Dave
2006 TBSS Black AWD
May-07-12, 09:06 AM
#4
Member # 7235
I use a 50/50 mix and it works great for cooling. If you go 100% and have a pump failure or clog a nozzle I would think it would result badly. Matt. Why do you recommend 100% methanol? Isn't it more corrosive with 100% methanol?
May-07-12, 09:17 AM
#5
Oil Rat, Oil & fuel parts
Real Name: Ross
Member # 61
Meth should be used as an octane enhancer before a way of cooling the intake charge.
IMO.
.....TBSS 11.02@ 123mph 7000DA..............
May-07-12, 09:32 AM
#6
Hazing 4th
Real Name: Matt
Member # 64
Status:
Online
It is a band aid for pump gas. You want it to work as well as possible and you can put safety features in the tune if you spray in front of the IAT sensor.
08' C6 M6 743/647
06' RCSB H/C
May-07-12, 09:50 AM
#7
Real Name: Caleb
Member # 12890
Status:
Online
I am running the V1 HOB kit, but changed out the intercooler setup to make it more efficient. I am running a 4" intake into the supercharger and 3" intercooler tubing and into the intake. The intercooler is larger now than the original V1 intercooler.
I have seen 16 pounds of boost on the boost gauge after the upgrades and would like to put the Meth injection on it before I get it all retuned and setup. It is parked for now awaiting the Meth injection setup and a tune.
I just have to figure out which direction I want to go and find someone that can tune it.
May-07-12, 10:01 AM
#8
Hazing 4th
Real Name: Matt
Member # 64
Status:
Online
Get an Alky control kit and go with someone that has tuning experience with meth.
08' C6 M6 743/647
06' RCSB H/C
May-07-12, 10:09 AM
#9
Real Name: Caleb
Member # 12890
Status:
Online
You wouldn't know of anyone in the southeast would you? I know of a couple tuners, but not sure if they have any experience tuning meth systems. I don't think they do. And I don't want to be their experiment either.
May-07-12, 10:25 AM
#10
Hazing 4th
Real Name: Matt
Member # 64
Status:
Online
Try Hinson Supercars they are in AL. I have no direct experience though.
08' C6 M6 743/647
06' RCSB H/C
May-07-12, 11:01 AM
#11
Member # 7235
Did you change the intercooler or just upgrade the piping? I have an F1D with a built 416 pushing 15-17lbs of boost on a dedicated drive. You have to have belt slip if you have the V1 bracket
May-07-12, 12:25 PM
#12
Real Name: Caleb
Member # 12890
Status:
Online
Changed the intercooler and upgraded the piping. It is running a belly mounted intercooler setup like Steve (Evill SS) had on his which is larger and reduces the length of the intercooler tubing as well over the V1 setup. I wish I had the dedicated drive setup, but I don't want to pay that much for the bracket's. I'll just make due with what I have for now.
There is some belt slip on decel after WOT, but I have only went WOT a handful of times since I upgraded it and won't be driving it much until I get Meth installed and retune it. I keep the belt tightened up like it says in the manual, but it's not going to be as good as a dedicated drive setup.
I was told it was setup for 8-10 when I bought the SS. It acts like a totally different animal when you go WOT at 16, which I only did to see if I would get an increase after the intercooler upgrades.
May-07-12, 02:32 PM
#13
Member # 3206
Agreed. We run 100% meth in everything we build. VP M1
May-07-12, 06:12 PM
#14
Tuner at PCMofnc.com
Real Name: Alvin
Member # 220
100% meth. The car should need it too. Its not going to pickup anything if the IAT's are already cool and timing is not an issue. I just finished tuning a 2010 turbo car with a alcohol kit 50/50. I told the guys not to do it since I already had 18-20 degrees of timing in it with no knock and the IAT's where only going from 99 F to 120F with no alcohol injection. It made less power than without the water/alcohol. One day people will start listening to the tuners on this!
A car that needs it will be octane limited or have high intake air temps.
PCMofNC.com PCM of NC, INC - 704-307-4227
May-07-12, 08:07 PM
#15
Real Name: Caleb
Member # 12890
Status:
Online
This is exactly why I posted the question. I wanted to get the input from tuners and people that had setups in place already.
May-07-12, 08:11 PM
#16
12 Second Club
Real Name: Cuzn Vinny
Member # 2121
Matt at Tune Time Performance in Toms River has my setup spraying 100% Meth Injection. When I asked why is isn't a 50/50 mix his answer to me was "Why would you want to spray something into your motor that doesn't burn?"
If your Meth setup is all under the hood I'd say do a 100% setup. But if you are installing a tank inside the vehicles cabin I would run a 50/50 mix.
100% = Extremely Flammable
50/50 Mix = Non Flammable
If ever an accident occurs I would hate to think of how dangerous it would be to get doused with a highly flammable liquid while possibly trapped in the vehicle and some sort of spark to ignite it.
But that's just me. I'm more concerned with my safety than I am of how much extra timing I can run.
LS1 Fans, Keystone Hood & CAI Box, 100% Meth, LS7 TB, 60# Injectors, 112HH@12#'s, IW 10% 8-Rib & 2.7" RIP, Blower Cam, ARH 1 7/8" Catless, RPM Level VI, 3200 Triple Disk, Stock Motor, 521HP / 546 TQ
May-08-12, 04:09 PM
#17
Real Name: Justin
Member # 15947
Meth can be tuned for incase the pump fails you just got to relocate the IAT sensor to about 2" down stream of the meth injection point. Most of the kit suppliers have the IAT relocation harness available for about $80.
OP I've got an aggressive dual nozzle set up and based on the drop in percent of injector DC, in my case roughly 20% of my fuel is 119 octane VP M1 meth. This mixed with 80% 93 and you are at about 98.X octane. Now as far as the cooling benefit, IAT's on a D1(@12-16psi) should drop from about 30-40 over ambient to about 20-30 below ambient temps after meth injection. Now that is a huge drop in temps and can be tuned to pull timing(as temps rise) in the case of pump failure.
IMO.
Why so? Have you spraying post blower yet? I don't think the added octane is that much. 3-5 octane numbers at best if you are really aggressive with it. I'd think the 70 to 80 degree temp drops would be just as helpfull at allowing more timing as a meager bump in octane would.
08 3SS AWD, 4L80, 402ci, LS3 P/P'd, HOB V2 F1D & Meth, lotsa METH!! 1.587 60ft 11.04@122 on a broken front Diff.
Reason: more info
May-08-12, 04:21 PM
#18
Real Name: Jared
Member # 9935
The first injection was water to cool the engine in WWII I think. Then, they discovered meth works better, so they started using it. 100% meth gives both octane and cooling. Win/win. Water had it's place, and has now been replaced.
May-08-12, 05:44 PM
#19
12 Second Club
Member # 2121
The first injection was water only, but they discovered that the water froze in the high altitude and cold climates. So adding a 50% mix of meth prevents it from freezing. Just like wash fluid with it's 20% blend of Meth.
Aug-24-12, 09:22 PM
#20
Real Name: nate
Member # 6460
Well put! I agree with the safety of 50/50 mix versus 100%...at least on a street truck
 LEP Tune, Gutted Cats, Resonator Delete, Pypes M80 muffler, Billet 2-4 Servo, Trans Cooler, TR6 Plugs, Massive Wires, K&N CAI, Rear bags dropped, KW Coilovers, Rear emblem delete, 1 inch rear spacers, LS1 Fans, Circle D Converter. 13.61@98 2300 DA 1.90 60ft
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
