Go Back   TBSSOWNERS.com Forums - The #1 TrailblazerSS Dedicated Owners Forum > TBSS Modifications > TBSS Elect/Mechanical Info Charts
Old May-31-12, 06:01 AM   #21
Not Brian
Not Brian's Avatar
Real Name: Brian
Member # 16678
Casino cash: $105412
Rep Power: Not Brian is a splendid one to beholdNot Brian is a splendid one to beholdNot Brian is a splendid one to beholdNot Brian is a splendid one to beholdNot Brian is a splendid one to beholdNot Brian is a splendid one to behold
Imagine a warped metal disc spinning like a top and you slowly lower a piece of sandpaper down on it. It randomly pops up at any speed almost always while slighty turning left. I've never heard an ABS system sound like a scraping noise when it turns on and my brake pedal doesn't vibrate, but it is on-and-off real fast like ABS.
Old May-31-12, 06:23 AM   #22
Hoosierdaddy
I can break it!
Hoosierdaddy's Avatar
Real Name: Jerod
Member # 4142
Casino cash: $121700
Rep Power: Hoosierdaddy is a splendid one to beholdHoosierdaddy is a splendid one to beholdHoosierdaddy is a splendid one to beholdHoosierdaddy is a splendid one to beholdHoosierdaddy is a splendid one to beholdHoosierdaddy is a splendid one to beholdHoosierdaddy is a splendid one to behold
Sounds exactly like a hub. Mine did the exact same thing, but hub didn't really show wear. Changed out hub and the noise was gone. As for the stabilitrak I would take a close look at the reluctor teeth and the densitometer pick ups on all 4 corners. Make sure there's not a bunch of crap built up in the reluctor wheels on the axles. If so just take some brake cleaner with a straw and clean everything real good. I've seen a similar issue when the reluctor was full of grease and brake dust. You could also have a bad or intermittent sensor.
Old May-31-12, 11:29 AM   #23
Not Brian
Not Brian's Avatar
Real Name: Brian
Member # 16678
Is there any way to test it before blowing my load on a new one? I'm not one to just throw parts at something until it's fixed.
Old May-31-12, 04:30 PM   #24
Hoosierdaddy
I can break it!
Real Name: Jerod
Member # 4142
Get somebody to ride along side you and try and pinpoint where the noise is coming from exactly and start from there.
Old May-31-12, 06:08 PM   #25
mrinken
What's SS stand for?
mrinken's Avatar
Real Name: Matt
Member # 10112
Casino cash: $415100
Rep Power: mrinken has a brilliant futuremrinken has a brilliant futuremrinken has a brilliant futuremrinken has a brilliant futuremrinken has a brilliant futuremrinken has a brilliant futuremrinken has a brilliant futuremrinken has a brilliant futuremrinken has a brilliant futuremrinken has a brilliant futuremrinken has a brilliant future
Old Jun-02-12, 07:33 PM   #26
APSGTO
Real Name: Justin
Member # 15947
Casino cash: $89600
Rep Power: APSGTO will become famous soon enoughAPSGTO will become famous soon enough
The scraping noise is the brakes being applied by the stabilatrac. Sometimes when it activates it can apply the brake quite hard. On the Vettes it would lock up one brake at 70mph on the front L or R side and try to though the car off the highway. The problem isn't as bad for the TBSS luckily but still an issue. GM's "STABILATRAC" is the problem.
08 3SS AWD, 4L80, 402ci, LS3 P/P'd, HOB V2 F1D & Meth, lotsa METH!! 1.587 60ft 11.04@122 on a broken front Diff.
Old Jun-07-12, 06:10 AM   #27
mrinken
mrinken's Avatar
Real Name: Matt
Member # 10112
Originally Posted by ForceFed View Post
I have a way to make the stabilitrack stay off every time it's started.
ITs not beem Tested on a TBSS "YET" but I am sure it will work. Let me contact the guy who makes them and see if he still wants to test on on a TBSS.
Any update on this? Will it still bring up the ABS/brake/traction control light?
Old Jun-07-12, 12:53 PM   #28
Not Brian
Not Brian's Avatar
Real Name: Brian
Member # 16678
But the truck doesn't slow down and the wheels don't jerk or anything.
Old Jun-07-12, 02:59 PM   #29
APSGTO
Real Name: Justin
Member # 15947
Casino cash: $89600
Does it fall on its face? Kills the engine for 3-5 seconds? If so that is how the stabilicrap behaves on the trailblazer.
Old Jun-07-12, 03:46 PM   #30
Not Brian
Not Brian's Avatar
Real Name: Brian
Member # 16678
Yep falls on its face and goes away. But I'm also having the second problem of the brakes, or something, making scrapey noises.
Oh and actually hitting the brake pedal while it's doing it doesn't change the noise at all.
Old Jun-09-12, 03:47 PM   #31
Bad Monkey
Bad Monkey Racing
Bad Monkey's Avatar
Real Name: Damon
Member # 3977
Casino cash: $306290
Rep Power: Bad Monkey has a spectacular aura aboutBad Monkey has a spectacular aura aboutBad Monkey has a spectacular aura about
I am having a similar issue lately. Mostly a ghost, sorry to highjack but where is the sensor for the steering?
Sold
Old Jun-09-12, 05:55 PM   #32
Grocery Getter
Grocery Getter's Avatar
Real Name: Mike
Member # 15957
Casino cash: $286472
Rep Power: Grocery Getter has much to be proud ofGrocery Getter has much to be proud ofGrocery Getter has much to be proud ofGrocery Getter has much to be proud ofGrocery Getter has much to be proud ofGrocery Getter has much to be proud ofGrocery Getter has much to be proud ofGrocery Getter has much to be proud ofGrocery Getter has much to be proud of
Behind the steering wheel.
I'll continue to stick by my motto.....
Don't Talk about it, Be about it.
Old Jun-09-12, 10:18 PM   #33
APSGTO
Real Name: Justin
Member # 15947
Casino cash: $89600
Did you pull the fuse (#58 or #61) to disable Stabilatrac? I'd pull it just to make sure that is the only problem. The scrapy noises is livable, the fall on your face part is not. I pulled the fuse and the power cut still happens. Must be in the tune, because once the car's oil temp exceeds 160 the problem stops.
Old Jun-10-12, 08:01 AM   #34
Not Brian
Not Brian's Avatar
Real Name: Brian
Member # 16678
No I haven't pulled any fuses yet, hopefully that narrows it down.
Old Jun-10-12, 01:01 PM   #35
2fast4utbss
2fast4utbss's Avatar
Real Name: oz
Member # 6440
Casino cash: $120750
Rep Power: 2fast4utbss is on a distinguished road
mine did the same thing this morning
Old Jun-10-12, 04:46 PM   #36
mrinken
mrinken's Avatar
Real Name: Matt
Member # 10112
Pull fuse #61.
Old Jun-10-12, 04:54 PM   #37
TmanSC07TBSS
TmanSC07TBSS's Avatar
Real Name: Wylie T.
Member # 9846
Casino cash: $871700
Rep Power: TmanSC07TBSS has a brilliant futureTmanSC07TBSS has a brilliant futureTmanSC07TBSS has a brilliant futureTmanSC07TBSS has a brilliant futureTmanSC07TBSS has a brilliant futureTmanSC07TBSS has a brilliant futureTmanSC07TBSS has a brilliant futureTmanSC07TBSS has a brilliant futureTmanSC07TBSS has a brilliant futureTmanSC07TBSS has a brilliant futureTmanSC07TBSS has a brilliant future
I pulled my #61 fuse a couple of weeks ago. The Stabilitrac just can't handle 500+ HP. They act funky with 400 HP. Good luck with the fix on this.
[07 Black 3SS ; Maggie 2300, Built 4L85e w/Trans Cooler, SW Hdrs w/True SW Duals, CAI, LS1 Efans, Custom Seat Inlays & Dash Bezel, D&S Rtrs, Keystone Hood, 3 Gauge Pillar Pod, Lowered, Pioneer DVD, Tinted Bermuda Tails, PCMforLess Dyno Tune and much more.
Old Jun-10-12, 05:17 PM   #38
gyrly78
gyrly78's Avatar
Real Name: Andi
Member # 2246
Casino cash: $90200
Rep Power: gyrly78 is on a distinguished road
I've had this happen everytime i drove it for about 2 weeks straight about a month or 2 ago. Then it's stopped and hasn't done it again since. Nothing has been changed, didn't touch tire pressure, fuses or tune. My truck was completely stock when this happened, but I'm about to get a new tune and CAI, but nothing is installed yet. Will the tune help, hurt, or not affect it at all?
BLACK 07 TBSS AWD 3SS
Old Jun-11-12, 05:28 AM   #39
mrinken
mrinken's Avatar
Real Name: Matt
Member # 10112
It shouldn't affect it at all, unless you're modding enough to put over 450 hp to the wheels. (I think that's the number) I believe at that hp rating the stabilitrac disables itself as it knows it can't handle that much power. (Or something like that)
Old Jun-11-12, 09:12 AM   #40
gyrly78
gyrly78's Avatar
Real Name: Andi
Member # 2246
Casino cash: $90200
Haha, I wish a tune and CAI would give me 450 to the wheels!!
